I’ve got some room-thermometer and wanted to be warned, if I forget to close the window after letting fresh air in.
I did not find a plug’n play solution, so this helped.
- platform: statistics
name: "conf Mittelwert Temperatur Buero"
unique_id: "conf_mittelwert_temperatur_buero"
entity_id: sensor.meter_pro_co2_df2f_temperatur
state_characteristic: mean
max_age:
hours: 2
template:
- sensor:
- name: "conf_diff Temperatur zu Mittelwert Büro"
unique_id: "conf_diffTemperaturZuMittelwertBuero"
unit_of_measurement: '°C'
device_class: "temperature"
state: >-
{{ float(states('sensor.conf_mittelwert_temperatur_buero')) - float(states('sensor.meter_pro_co2_df2f_temperatur')) | round(2) }}
And then you only have to watch if conf_diff_Temp… is over 1 to 1.5
