Open zwave add-on
If we are already leveraging the zwave integration in HASSIO. I’m assuming that the open zwave add-on would replace that integration?
There’s no current plan to deprecate the existing zwave integration, Open Zwave would just be another option (and probably the recommended way in future).
But you cannot run them together correct?
You could if you had two separate Z-Wave sticks, but not for the same Z-Wave network.
I think you can, with 2 seperate zwave stick and have 1 of 2 as secondary controller?
It’s probably not going to work that well. Both controllers would “fight” for control and you probably would have very inconsistent states between the two as they are completely different versions.
Yes that’s true, ozw 1.4 vs 1.6… but in theory it would work :slight_smile: you can also set the 1.4 to be a slave controller though. but better to have 1 source of truth.
Thanks, just looking at options without going full blown on the new zwave path yet.
