openDTU some missing MQTT topics
Hi there.
i’m new to this forum. it has given me good advice a few times, but now i have a probably small problem where i stumble.
I use openDTU with a Hoymiles HM300. Works also everything in principle, openDTU was recognized in the HomeAssistant via MQTT and there are numerous sensor values available also the power can be limited.
Some values are not supplied however as sensor values in the Homeassistant however e.g. the DC voltage, which I want to use absolutely. In the MQTT explorer these values are also available for String1.
How can I get these values also accessible? Do I have to generate a sensor in the mqtt-yaml? Or can I add this where the other sensors are generated? Where does this take place? (basic question)
thanks, folks!
Hi. no suggestions?
