Good morning guys,
I don’t know if anybody else reported or experienced some issue with “OpenGarage” so far. But since yesterday after upgrading to 0.111, my opengarage integration stopped working for me.
Working fine here.
Anything in your logs on it?
Thank you for replying; so far i’m going through and i don’t see anything related to opengarage. It’s like the component does not even load.
Same issue here. Went from 0.110 to 0.112 and the “covers” for opengarage no longer load. There are sensors created to show status but no way to control them any more. There are no errors, notifications, or relevant log entries.
Power cycle your opengarage, then reboot HA. That did the trick for me
I have two instances of 0.112.4 on dev and prod environments. Dev is running fine, no issue but prod server is not loading Opengarage and giving the below error in log file:
2020-07-15 16:51:28 ERROR (MainThread) [opengarage] Error connecting to Open garage: None
File "/usr/local/lib/python3.7/site-packages/opengarage/__init__.py", line 54, in _execute
resp = await self.websession.get(url, verify_ssl=self._verify_ssl)
File "/usr/local/lib/python3.7/site-packages/aiohttp/client.py", line 504, in _request
await resp.start(conn)
File "/usr/local/lib/python3.7/site-packages/aiohttp/client_reqrep.py", line 847, in start
message, payload = await self._protocol.read() # type: ignore # noqa
File "/usr/local/lib/python3.7/site-packages/aiohttp/streams.py", line 591, in read
await self._waiter
aiohttp.client_exceptions.ServerDisconnectedError: None
2020-07-15 16:51:28 ERROR (MainThread) [homeassistant.components.cover] Error while setting up opengarage platform for cover
Awaiting 0.112.5 to be available to my instance, if that will fix the issue. The version 0.112.5 is visible at HA website. Thanks.
No issues here running 0.112.4 and OpenGarage Firmware v1.1.0.
