I have added a openhasp display to the setup, and configured the MQTT part on it.
I can see with a MQTT explorer, that the display is present in MQTT - but for some reason the openhasp integration doesn’t seem to intercept/find the dsiplay …
Hello, I had exactly the same issue but everything is working fine now !!! I you device has been set recently it is in version 0.7.0 but openhasp is loaded in HACS store in 0.6.6 version. These versions are incompatible between them. You have to go back in the HACS store in home assistant. You have to reload OPENHASP but by selecting “allow BETA version” . After you can select a version higher than 0.7.0. I downloaded the version 0.7.2.
