I would like to have the possibility to specify opening and closing state in the value template for cover template.
As it is now it only supports:
Defines a template to get the state of the cover. Valid values are open
/ true
or closed
/ false
. [ value_template
So the case i would like to be able to use is:
value_template: >-
{% if is_state('cover.xxx', 'closing') %}
closing
{% elif is_state('cover.xxx', 'opening') %}
opening
{% elif is_state('binary_sensor.door_sensor', 'on') %}
open
{% else %}
closed
{% endif %}
