OpenStreetMap not loading streets at all
Hi there,
I’m having lots of problems loading maps, most of times, and I mean really most (>80%) the map loads with all places pinned, the user locations correct (relative in space), but no streets at all are loaded, the background is black (or white depending on theme).
Example:
Is anyone else having the same problem?
Does anyone know the cause and how to fix this?
If not, then I guess I’ll open an issue on github.
Cheers,
Never mind… the sooner I would post this the sooner I would find the root cause.
It was not a HASS problem, it was my site’s CSP who was blocking cartocdn.com.
As a follow-up note for those who might be experiencing a similar problem: my old wall-mounted tablet running Fully Kiosk now doesn’t support new enough SSL ciphers for the map CDN, so can’t load maps.
