Hi, I’m using the Opentherm Gateway (opentherm_gw or OTGW). Sometimes the gateway becomes unavailable. I found the issue, which is that the gateway is going into Print Summary mode (PS=1). I do not understand why this is happening. I was wondering if it is possible to send an PS=0 command from Home Assistant? If this is possible, I can make an automation that sends this command when it becomes unavailable. Now I have to startup otmonitor and send the PS=0 command manually. Or maybe someone has the same issue and has a different solution?
