Opentherm gateway (OTGW) no stable connection after moving HA to docker
I have been running HA stable for years with OTGW, connecting via TCP (ESP-12) and using the HA integration.
Recently I moved HA to a docker environment, and everything works fine except the OTGW: The connections is not stable which results in the log:
2020-08-29 09:25:08 ERROR (MainThread) [pyotgw.pyotgw] Could not connect to serial device on socket://ESP-12-OTGW.fritz.box:23. Will keep trying. Reported error was: Could not open port socket://ESP-12-OTGW.fritz.box:23: timed out
This happens about 5 - 20 times every hour or so.
I run latest versions of everything, Any other OTGW users with this issue? Is it a problem with my configuration? Is it a bug?
Any help would be appreciated!
