Yes! It’s here. The OpenThermGateway platform is added to HA 0.78.0. But i can’t get it up and running.
Probably due to one of these reasons:
I have a OTG (USB version) which uses an USB over Ethernet adapter to get connected, what worked as suspected on my VERA.
I can’t identify the right usb port
When restarting hassio i got the following two errors:
Setup of platform opentherm_gw is taking over 10 seconds.
and:
Error doing job: Task exception was never retrieved
File “/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py”, line 342, in _async_add_entity
await entity.async_added_to_hass()
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/climate/opentherm_gw.py”, line 66, in async_added_to_hass
await self.gateway.connect(self.hass.loop, self._device)
File “/usr/local/lib/python3.6/site-packages/pyotgw/pyotgw.py”, line 55, in connect
await self.get_reports()
File “/usr/local/lib/python3.6/site-packages/pyotgw/pyotgw.py”, line 170, in get_reports
OTGW_DEFAULT_TIMEOUT, loop=self.loop)
File “/usr/local/lib/python3.6/asyncio/tasks.py”, line 362, in wait_for
raise futures.TimeoutError()
concurrent.futures._base.TimeoutError
I have the exact same error using serial over Ip ( Ser2Net with nodeMCU)
Cannot get it to work…
018-09-19 13:55:54 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 342, in _async_add_entity
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/climate/opentherm_gw.py", line 66, in async_added_to_hass
File "/usr/local/lib/python3.6/site-packages/pyotgw/pyotgw.py", line 55, in connect
File "/usr/local/lib/python3.6/site-packages/pyotgw/pyotgw.py", line 170, in get_reports
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 362, in wait_for
I have OTG connected via USB to my Vera, works great.
Now I want to switch to HA, and use the Vera integration to get my Vera devices in HA, including the temperature via OTG.
Also works great, that is, I can see the temperature, but if I want to change the temperature, this does not work.
Any Ideas about this?
Just out of curiosity. Why still use your VERA for this and not just connect the OTG directly to your hassio and use the hassio otg integration? Works like a charm. Also for setting the temperature.
Hi @bartandeweg,
Good point, I am investigating this.
My OTG is a USB version, and my vera is located near the OTG. My Home Assistent is on a ESXi, that is not nearby.
But I am thinking of adding a network connection to my OTG. But my OTG is quite old, I am not sure if this would fit.
I also was a VERA user but switched over to Home Assistant totally. Best decision i made in terms of home automation.
Also i was using an old version of the OTG working on USB. I extended this USB with a ethernet extender but this was nog working very stable. I decided to build a new one with etherent on board and this runs very stable. Worth the €30.
Thats good to know.
I was thinking of doing the same. but noticed that a ethernet connection is not (out of the box) possible.
Which OTG did you buy? for 30 Euro, that seems to be the best choice.
