OpenUV component - remains enabled
I have been having trouble with the OpenUV components api so I disabled it by removing it from my configuration.yaml. However, when starting HA it still tries to load it:
2018-11-02 14:16:07 WARNING (MainThread) [homeassistant.config_entries] Config entry for openuv not ready yet. Retrying in 10 seconds.
2018-11-02 14:16:07 ERROR (MainThread) [homeassistant.components.openuv] Config entry failed: Invalid API key
2018-11-02 14:16:18 ERROR (MainThread) [homeassistant.components.openuv] Config entry failed: Invalid API key
2018-11-02 14:16:18 WARNING (MainThread) [homeassistant.config_entries] Config entry for openuv not ready yet. Retrying in 20 seconds.
How can I disable this?
My Configuration.yaml:
homeassistant:
  latitude: !secret home_latitude
  longitude: !secret home_longitude
  elevation: !secret home_elevation
  time_zone: !secret home_timezone
  unit_system: metric
  # Customization file
  customize: !include customize.yaml
# Enables the frontend with themes
frontend:
  themes: !include_dir_merge_named themes
# Enables configuration UI
config:
http:
  base_url: !secret base_url
  ip_ban_enabled: True
  login_attempts_threshold: 5
  trusted_networks: 192.168.0.0/24
# Enable the Updater
updater:
# Enables support for tracking state changes over time
history:
  exclude:
    domains:
      - updator
      - discovery
      - switch
    entities:
      - sun.sun
      - sensor.sandymount_tide
# Configure the history component with recorder
recorder:
  purge_interval: 7
  purge_keep_days: 14
  exclude:
    domains:
      - automation
      - updator
      - discovery
    entities:
      - sun.sun
# View all events in a logbook
# logbook:
weather:
  - platform: darksky
    api_key: !secret darksky_api_key
# Track the sun
sun:
########### Includes ###########
group: !include groups.yaml
device_tracker: !include_dir_list presence_detection/
sensor: !include_dir_list sensors/
switch: !include_dir_list switches/
camera: !include_dir_list cameras/
Thanks,
Dan
Have you enabled it also via Integrations?
if so, you may need to remove from there also
Yes thank you. Iā€™d forgotten to remove it from Integrations. Removing it from here has fully disabled it.
