I use my Home Assistant (connected via ethernet to the router) as wifi access point to share internet, and I want to install OpenVpn (config provided by S*rfshark) and route all the traffic (local and from the access point Wifi) over the VPN.
Here the output of ifconfig:
br-5fa5a7c5472b: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.20.0.1 netmask 255.255.255.0 broadcast 172.20.0.255
ether 5e:e6:c0:03:3a:17 txqueuelen 0 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 188 overruns 0 carrier 0 collisions 0
docker0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 172.30.232.1 netmask 255.255.254.0 broadcast 172.30.233.255
inet6 fde0:fa7a:42cc::1 prefixlen 64 scopeid 0x0<global>
inet6 fe80::4c15:c1ff:fe30:6099 prefixlen 64 scopeid 0x20<link>
ether 4e:15:c1:30:60:99 txqueuelen 0 (Ethernet)
RX packets 27673 bytes 7040097 (6.7 MiB)
TX packets 32212 bytes 13618231 (12.9 MiB)
TX errors 0 dropped 4 overruns 0 carrier 0 collisions 0
end0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.2.114 netmask 255.255.255.0 broadcast 192.168.2.255
inet6 2a00:1f:9d02:2901:e6b3:86ca:807a:c844 prefixlen 64 scopeid 0x0<global>
inet6 fe80::e0a5:7e03:bac1:5296 prefixlen 64 scopeid 0x20<link>
ether 2c:cf:67:33:ad:e4 txqueuelen 1000 (Ethernet)
RX packets 2545517 bytes 784995961 (748.6 MiB)
TX packets 2303989 bytes 300975919 (287.0 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 107
hassio: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 172.30.32.1 netmask 255.255.254.0 broadcast 172.30.33.255
inet6 fd0c:ac1e:2100::1 prefixlen 48 scopeid 0x0<global>
inet6 fe80::343d:f9ff:fea5:b0eb prefixlen 64 scopeid 0x20<link>
ether 36:3d:f9:a5:b0:eb txqueuelen 0 (Ethernet)
RX packets 1636531 bytes 680682552 (649.1 MiB)
TX packets 1679418 bytes 294283068 (280.6 MiB)
TX errors 0 dropped 2 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 519835 bytes 139112399 (132.6 MiB)
TX packets 519835 bytes 139112399 (132.6 MiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.10.1 netmask 255.255.255.0 broadcast 192.168.10.255
ether 2c:cf:67:33:ad:e6 txqueuelen 1000 (Ethernet)
RX packets 5742418 bytes 1054308214 (1005.4 MiB)
TX packets 588446 bytes 399390470 (380.8 MiB)
This is the client.ovpn
client
dev tun
proto tcp
remote <server_host> <server_port>
remote-random
nobind
tun-mtu 1500
mssfix 1450
ping 15
ping-restart 0
reneg-sec 0
remote-cert-tls server
auth-user-pass pass.txt
verb 3
fast-io
cipher AES-256-CBC
auth SHA512
key-direction 1
tls-auth ta.key 1
ca ca.crt
Here is the output of the ip route:
0.0.0.0/1 via 10.7.7.1 dev tun0
default via 192.168.2.1 dev end0 src 192.168.2.114 metric 100
10.7.7.0/24 dev tun0 scope link src 10.7.7.3
37.19.200.103 via 192.168.2.1 dev end0
128.0.0.0/1 via 10.7.7.1 dev tun0
172.20.0.0/24 dev br-5fa5a7c5472b scope link src 172.20.0.1
172.30.32.0/23 dev hassio scope link src 172.30.32.1
172.30.232.0/23 dev docker0 scope link src 172.30.232.1
192.168.2.0/24 dev end0 scope link src 192.168.2.114 metric 100
192.168.10.0/24 dev wlan0 scope link src 192.168.10.1
As it is:
- from within Home Assistant, it seems my requests goes through the VPN
- when connecting a device using the access point, it seems there is no internet connection
