OpenZwave 0.5.1 update fails
Hi
Anyone know what I am doing wrong?
20-07-13 14:39:12 INFO (SyncWorker_19) [supervisor.docker.interface] Update image homeassistant/armv7-addon-zwave:0.5.0 to homeassistant/armv7-addon-zwave:0.5.1
20-07-13 14:39:12 INFO (SyncWorker_19) [supervisor.docker.interface] Pull image homeassistant/armv7-addon-zwave tag 0.5.1.
20-07-13 14:39:14 ERROR (SyncWorker_19) [supervisor.docker.interface] Can't install homeassistant/armv7-addon-zwave:0.5.1 -> 404 Client Error: Not Found ("manifest for homeassistant/armv7-addon-zwave:0.5.1 not found: manifest unknown: manifest unknown").
FFS!
[20200713 17:41:24.617 CEST] [ozw.library] [debug]: Detail - Node: 12 Changes to this value are not verified
[20200713 17:41:24.617 CEST] [ozw.library] [info]: Info - Node: 12 Received Configuration report: Parameter=45, Value=2
[20200713 17:41:24.617 CEST] [ozw.library] [debug]: Detail - Node: 12 Notification: ValueRefreshed CC: COMMAND_CLASS_CONFIGURATION Instance: 1 Index: 45
[20200713 17:41:24.617 CEST] [ozw.notifications] [debug]: Notification pvt_valueRefreshed: 12666374163529745 Thread: 0x7fa602262d48
[20200713 17:41:24.619 CEST] [ozw.mqtt.publisher] [debug]: Publishing Event valueRefreshed: 12666374163529745
[20200713 17:41:25.193 CEST] [ozw.library] [debug]: Detail - Node: 12 Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0c, 0x05, 0x70, 0x06, 0x2d, 0x01, 0x02, 0xa1
[20200713 17:41:25.193 CEST] [ozw.library] [info]: Info - Node: 12 Response RTT 2215 Average Response RTT 1622
[20200713 17:41:25.193 CEST] [ozw.library] [debug]: Detail - Node: 12 Refreshed Value: old value=2, new value=2, type=byte
[20200713 17:41:25.193 CEST] [ozw.library] [debug]: Detail - Node: 12 Changes to this value are not verified
[20200713 17:41:25.193 CEST] [ozw.library] [info]: Info - Node: 12 Received Configuration report: Parameter=45, Value=2
[20200713 17:41:25.193 CEST] [ozw.library] [debug]: Detail - Node: 12 Notification: ValueRefreshed CC: COMMAND_CLASS_CONFIGURATION Instance: 1 Index: 45
[20200713 17:41:25.193 CEST] [ozw.notifications] [debug]: Notification pvt_valueRefreshed: 12666374163529745 Thread: 0x7fa602262d48
[20200713 17:41:25.194 CEST] [ozw.mqtt.publisher] [debug]: Publishing Event valueRefreshed: 12666374163529745
[20200713 17:41:25.455 CEST] [ozw.library] [debug]: Detail - Node: 12 Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0c, 0x05, 0x70, 0x06, 0x2d, 0x01, 0x02, 0xa1
[20200713 17:41:25.455 CEST] [ozw.library] [info]: Info - Node: 12 Response RTT 2477 Average Response RTT 2049
[20200713 17:41:25.455 CEST] [ozw.library] [debug]: Detail - Node: 12 Refreshed Value: old value=2, new value=2, type=byte
[20200713 17:41:25.455 CEST] [ozw.library] [debug]: Detail - Node: 12 Changes to this value are not verified
[20200713 17:41:25.455 CEST] [ozw.library] [info]: Info - Node: 12 Received Configuration report: Parameter=45, Value=2
[20200713 17:41:25.455 CEST] [ozw.library] [debug]: Detail - Node: 12 Notification: ValueRefreshed CC: COMMAND_CLASS_CONFIGURATION Instance: 1 Index: 45
[20200713 17:41:25.455 CEST] [ozw.notifications] [debug]: Notification pvt_valueRefreshed: 12666374163529745 Thread: 0x7fa602262d48
[20200713 17:41:25.456 CEST] [ozw.mqtt.publisher] [debug]: Publishing Event valueRefreshed: 12666374163529745
[20200713 17:41:25.976 CEST] [ozw.library] [debug]: Detail - Node: 12 Received: 0x01, 0x07, 0x00, 0x13, 0x65, 0x00, 0x01, 0x2b, 0xa4
[20200713 17:41:25.976 CEST] [ozw.library] [debug]: Detail - Node: 12 ZW_SEND_DATA Request with callback ID 0x65 received (expected 0x65)
[20200713 17:41:25.976 CEST] [ozw.library] [info]: Info - Node: 12 Request RTT 2998 Average Request RTT 1639
[20200713 17:41:25.976 CEST] [ozw.library] [debug]: Detail - Node: 12 Expected callbackId was received
[20200713 17:41:26.436 CEST] [ozw.library] [debug]: Detail - Node: 12 Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0c, 0x05, 0x70, 0x06, 0x2d, 0x01, 0x02, 0xa1
[20200713 17:41:26.436 CEST] [ozw.library] [info]: Info - Node: 12 Response RTT 3459 Average Response RTT 2754
[20200713 17:41:26.436 CEST] [ozw.library] [debug]: Detail - Node: 12 Refreshed Value: old value=2, new value=2, type=byte
[20200713 17:41:26.437 CEST] [ozw.library] [debug]: Detail - Node: 12 Changes to this value are not verified
[20200713 17:41:26.437 CEST] [ozw.library] [info]: Info - Node: 12 Received Configuration report: Parameter=45, Value=2
[20200713 17:41:26.437 CEST] [ozw.library] [debug]: Detail - Node: 12 Expected reply and command class was received
[20200713 17:41:26.437 CEST] [ozw.library] [debug]: Detail - Node: 12 Message transaction complete
[20200713 17:41:26.437 CEST] [ozw.library] [debug]: Detail - Node: 12 Removing current message
[20200713 17:41:26.437 CEST] [ozw.library] [debug]: Detail - Node: 12 Notification: ValueRefreshed CC: COMMAND_CLASS_CONFIGURATION Instance: 1 Index: 45
[20200713 17:41:26.437 CEST] [ozw.library] [info]: Info - Node: 12 Sending (Query) message (Callback ID=0x66, Expected Reply=0x04) - ConfigurationCmd_Get (Node=12): 0x01, 0x0a, 0x00, 0x13, 0x0c, 0x03, 0x70, 0x05, 0x30, 0x25, 0x66, 0xef
[20200713 17:41:26.437 CEST] [ozw.notifications] [debug]: Notification pvt_valueRefreshed: 12666374163529745 Thread: 0x7fa602262d48
[20200713 17:41:26.437 CEST] [ozw.library] [info]: Info - Node: 12 Encrypted Flag is 0
[20200713 17:41:26.438 CEST] [ozw.mqtt.publisher] [debug]: Publishing Event valueRefreshed: 12666374163529745
[20200713 17:41:26.449 CEST] [ozw.library] [debug]: Detail - Node: 12 Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
[20200713 17:41:26.449 CEST] [ozw.library] [debug]: Detail - Node: 12 ZW_SEND_DATA delivered to Z-Wave stack
[20200713 17:41:26.660 CEST] [ozw.library] [debug]: Detail - Node: 12 Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0c, 0x05, 0x70, 0x06, 0x2e, 0x01, 0x00, 0xa0
[20200713 17:41:26.660 CEST] [ozw.library] [info]: Info - Node: 12 Response RTT 223 Average Response RTT 1488
[20200713 17:41:26.661 CEST] [ozw.library] [debug]: Detail - Node: 12 Initial read of value
[20200713 17:41:26.661 CEST] [ozw.library] [info]: Info - Node: 12 Received Configuration report: Parameter=46, Value=0
[20200713 17:41:26.661 CEST] [ozw.library] [debug]: Detail - Node: 12 Notification: ValueChanged CC: COMMAND_CLASS_CONFIGURATION Instance: 1 Index: 46
[20200713 17:41:26.661 CEST] [ozw.notifications] [debug]: Notification pvt_valueChanged: 12947849140240404 Thread: 0x7fa602262d48
[20200713 17:41:26.661 CEST] [ozw.mqtt.publisher.value] [debug]: List Selected Value has Not Changed: “Disabled”
[20200713 17:41:26.662 CEST] [ozw.mqtt.publisher] [debug]: Publishing Event valueChanged: 12947849140240404
[20200713 17:41:27.600 CEST] [ozw.library] [debug]: Detail - Node: 12 Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0c, 0x05, 0x70, 0x06, 0x2e, 0x01, 0x00, 0xa0
[20200713 17:41:27.600 CEST] [ozw.library] [info]: Info - Node: 12 Response RTT 1162 Average Response RTT 1325
[20200713 17:41:27.600 CEST] [ozw.library] [debug]: Detail - Node: 12 Refreshed Value: old value=0, new value=0, type=list
[20200713 17:41:27.600 CEST] [ozw.library] [debug]: Detail - Node: 12 Changes to this value are not verified
[20200713 17:41:27.600 CEST] [ozw.library] [info]: Info - Node: 12 Received Configuration report: Parameter=46, Value=0
[20200713 17:41:27.600 CEST] [ozw.library] [debug]: Detail - Node: 12 Notification: ValueRefreshed CC: COMMAND_CLASS_CONFIGURATION Instance: 1 Index: 46
[20200713 17:41:27.600 CEST] [ozw.notifications] [debug]: Notification pvt_valueRefreshed: 12947849140240404 Thread: 0x7fa602262d48
[20200713 17:41:27.601 CEST] [ozw.mqtt.publisher.value] [debug]: List Selected Value has Not Changed: “Disabled”
[20200713 17:41:27.601 CEST] [ozw.mqtt.publisher] [debug]: Publishing Event valueRefreshed: 12947849140240404
[20200713 17:41:28.243 CEST] [ozw.library] [debug]: Detail - Node: 12 Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0c, 0x05, 0x70, 0x06, 0x30, 0x01, 0x00, 0xbe
[20200713 17:41:28.243 CEST] [ozw.library] [info]: Info - Node: 12 Response RTT 1806 Average Response RTT 1565
[20200713 17:41:28.243 CEST] [ozw.library] [debug]: Detail - Node: 12 Initial read of value
[20200713 17:41:28.243 CEST] [ozw.library] [info]: Info - Node: 12 Received Configuration report: Parameter=48, Value=0
[20200713 17:41:28.243 CEST] [ozw.library] [debug]: Detail - Node: 12 Notification: ValueChanged CC: COMMAND_CLASS_CONFIGURATION Instance: 1 Index: 48
[20200713 17:41:28.243 CEST] [ozw.notifications] [debug]: Notification pvt_valueChanged: 13510799093661722 Thread: 0x7fa602262d48
[20200713 17:41:28.244 CEST] [ozw.mqtt.publisher.value] [warning]: Bitset is Missing Position or Value Members, or Incorrect Types: “{\n “Label”: “Enable/disable to send a report on Threshold”,\n “Value”: [],\n “Units”: “”,\n “ValueSet”: false,\n “ValuePolled”: false,\n “ChangeVerified”: false,\n “Min”: 0,\n “Max”: 0,\n “Type”: “BitSet”,\n “Instance”: 1,\n “CommandClass”: “COMMAND_CLASS_CONFIGURATION”,\n “Index”: 48,\n “Node”: 12,\n “Genre”: “Config”,\n “Help”: “Enable/disable to send a report when the measurement is more than the upper limit value or less than the lower limit value. Note: If USB power, the Sensor will check the limit every 10 seconds. If battery power, the Sensor will check the limit when it is waken up.”,\n “ValueIDKey”: 13510799093661722,\n “ReadOnly”: false,\n “WriteOnly”: false,\n “Event”: “valueAdded”,\n “TimeStamp”: 1594654761\n}”
[20200713 17:41:28.244 CEST] [ozw.mqtt.publisher] [debug]: Publishing Event valueChanged: 13510799093661722
[20200713 17:41:28.355 CEST] [ozw.library] [debug]: Detail - Node: 12 Received: 0x01, 0x07, 0x00, 0x13, 0x66, 0x00, 0x00, 0xbf, 0x32
[20200713 17:41:28.355 CEST] [ozw.library] [debug]: Detail - Node: 12 ZW_SEND_DATA Request with callback ID 0x66 received (expected 0x66)
[20200713 17:41:28.355 CEST] [ozw.library] [info]: Info - Node: 12 Request RTT 1918 Average Request RTT 1778
[20200713 17:41:28.355 CEST] [ozw.library] [debug]: Detail - Node: 12 Expected callbackId was received
[20200713 17:41:28.425 CEST] [ozw.library] [debug]: Detail - Node: 12 Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0c, 0x05, 0x70, 0x06, 0x30, 0x01, 0x00, 0xbe
[20200713 17:41:28.425 CEST] [ozw.library] [info]: Info - Node: 12 Response RTT 1988 Average Response RTT 1776
[20200713 17:41:28.425 CEST] [ozw.library] [debug]: Detail - Node: 12 Refreshed Value: old value=0, new value=0, type=bitset
[20200713 17:41:28.425 CEST] [ozw.library] [debug]: Detail - Node: 12 Changes to this value are not verified
[20200713 17:41:28.425 CEST] [ozw.daemon] [warning]: =============================
[20200713 17:41:28.425 CEST] [ozw.daemon] [warning]: CRASH!!! - Dumping Backtrace:
[20200713 17:41:28.425 CEST] [ozw.daemon] [warning]: #1 0x00007fa60221327d sp=0x00007fa5ff201a80 sigwaitinfo + 0x8
[20200713 17:41:28.425 CEST] [default] [warning]: Exiting…
1594654888: Socket error on client qt-openzwave-1, disconnecting.
In exit
[cont-finish.d] executing container finish scripts…
[cont-finish.d] done.
[s6-finish] waiting for services.
s6-svwait: fatal: supervisor died
1594654888: mosquitto version 1.6.8 terminating
1594654888: Saving in-memory database to /data/mosquitto.db.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
Put this down to COVID-19. I must have been suffering from intermittent internet connections. It all worked when I retried a few hours later.
I get this same behavior whenever I start the OpenZWave addon after restarting MQTT or from a reboot of the host (I use the Mosquitto Broker from the Add-on store).
This has been consistent for me since starting to use the OpenZWave beta on Hass.io (in a VM).
My upgrade to 0.5.1 was not a good experience. It would crash as above. I finally had to restore to a backup. I suggest when you selectively restore like I did (openzwave) that you select the WIPE option. I didn’t and had subsequent problems with reboots of openzwave until I did that.
I note there is an issue opened on this as well so suggest folks stay careful about trying 0.5.1.
Cheers
