I tried to add it as encrypted and not encrypted with the same results. Log shows me the following.
[20200815 14:31:58.886 CDT] [default] [debug]: QVariant(QBitArray, QBitArray(1011 0111 0))
[20200815 14:31:58.933 CDT] [ozw.library] [debug]: Detail - Node: 25 Received: 0x01, 0x06, 0x00, 0x04, 0x00, 0x19, 0x00, 0xe4
[20200815 14:31:58.934 CDT] [ozw.library] [info]: Info - Node: 25 ApplicationCommandHandler - Unhandled Command Class 0xe4
[20200815 14:31:59.293 CDT] [ozw.library] [debug]: Detail - Node: 25 Received: 0x01, 0x11, 0x00, 0x04, 0x00, 0x19, 0x0b, 0x60, 0x0d, 0x00, 0x01, 0x60, 0x0d, 0x00, 0x00, 0x25, 0x03, 0xff, 0x20
[20200815 14:31:59.294 CDT] [ozw.library] [info]: Info - Node: 25 MultiChannelEncap with endpoint set to 0 - Send to Root Device
[20200815 14:31:59.294 CDT] [ozw.library] [info]: Info - Node: 25 Received SwitchBinary report from node 25: level=On
[20200815 14:31:59.294 CDT] [ozw.library] [debug]: Detail - Node: 25 Value Updated: old value=true, new value=true, type=bool
[20200815 14:31:59.294 CDT] [ozw.library] [debug]: Detail - Node: 25 Changes to this value are not verified
[20200815 14:31:59.294 CDT] [ozw.library] [debug]: Detail - Node: 25 Notification: ValueRefreshed CC: COMMAND_CLASS_SWITCH_BINARY Instance: 1 Index: 0
[20200815 14:31:59.295 CDT] [ozw.notifications] [debug]: Notification pvt_valueRefreshed: 424230928 Thread: 0x7fe546b4ed48
[20200815 14:31:59.297 CDT] [ozw.mqtt.publisher] [debug]: Publishing Event valueRefreshed: 424230928
[20200815 14:31:59.489 CDT] [ozw.library] [debug]: Detail - Node: 25 Received: 0x01, 0x11, 0x00, 0x04, 0x00, 0x19, 0x0b, 0x60, 0x0d, 0x01, 0x01, 0x60, 0x0d, 0x01, 0x01, 0x25, 0x03, 0xff, 0x21
[20200815 14:31:59.490 CDT] [ozw.library] [info]: Info - Node: 25 Received a MultiChannelEncap from node 25, endpoint 1 for Command Class COMMAND_CLASS_MULTI_INSTANCE/CHANNEL
[20200815 14:31:59.490 CDT] [ozw.library] [info]: Info - Node: 25 Received a MultiChannelEncap from node 25, endpoint 1 for Command Class COMMAND_CLASS_SWITCH_BINARY
[20200815 14:31:59.490 CDT] [ozw.library] [info]: Info - Node: 25 Received SwitchBinary report from node 25: level=On
[20200815 14:31:59.491 CDT] [ozw.library] [debug]: Detail - Node: 25 Value Updated: old value=true, new value=true, type=bool
[20200815 14:31:59.491 CDT] [ozw.library] [debug]: Detail - Node: 25 Changes to this value are not verified
[20200815 14:31:59.491 CDT] [ozw.library] [debug]: Detail - Node: 25 Notification: ValueRefreshed CC: COMMAND_CLASS_SWITCH_BINARY Instance: 2 Index: 0
[20200815 14:31:59.492 CDT] [ozw.notifications] [debug]: Notification pvt_valueRefreshed: 424230944 Thread: 0x7fe546b4ed48
[20200815 14:31:59.493 CDT] [ozw.mqtt.publisher] [debug]: Publishing Event valueRefreshed: 424230944
[20200815 14:31:59.617 CDT] [ozw.library] [debug]: Detail - Node: 25 Received: 0x01, 0x11, 0x00, 0x04, 0x00, 0x19, 0x0b, 0x60, 0x0d, 0x02, 0x01, 0x60, 0x0d, 0x02, 0x02, 0x25, 0x03, 0xff, 0x22
[20200815 14:31:59.617 CDT] [ozw.library] [info]: Info - Node: 25 Received a MultiChannelEncap from node 25, endpoint 2 for Command Class COMMAND_CLASS_MULTI_INSTANCE/CHANNEL
[20200815 14:31:59.618 CDT] [ozw.library] [info]: Info - Node: 25 Received a MultiChannelEncap from node 25, endpoint 2 for Command Class COMMAND_CLASS_SWITCH_BINARY
[20200815 14:31:59.618 CDT] [ozw.library] [info]: Info - Node: 25 Received SwitchBinary report from node 25: level=On
[20200815 14:31:59.618 CDT] [ozw.library] [debug]: Detail - Node: 25 Value Updated: old value=true, new value=true, type=bool
[20200815 14:31:59.618 CDT] [ozw.library] [debug]: Detail - Node: 25 Changes to this value are not verified
[20200815 14:31:59.618 CDT] [ozw.library] [debug]: Detail - Node: 25 Notification: ValueRefreshed CC: COMMAND_CLASS_SWITCH_BINARY Instance: 3 Index: 0
[20200815 14:31:59.619 CDT] [ozw.notifications] [debug]: Notification pvt_valueRefreshed: 424230960 Thread: 0x7fe546b4ed48
[20200815 14:31:59.622 CDT] [ozw.mqtt.publisher] [debug]: Publishing Event valueRefreshed: 424230960
[20200815 14:32:14.452 CDT] [ozw.mqtt.publisher] [debug]: "Sat Aug 15 14:32:14 2020 PingResponse\n"
[20200815 14:32:17.452 CDT] [default] [debug]: QVariant(int, 1)
In OpenZWave add-on I added the network key, but it does not offer me to enter it anywhere when I add a new node.
