I’m adding a Everspring HSM02 but it’s recognized as an Everspring SM103. Both are door/window sensor but are not the same.
Browsing in the openzwave directory on my PI I also don’t see the HSM02 (but the SM103 is present). On the openzwave website I have found the xml file for the HSM02. Added this to the directory which also holds the SM103. Did an exclude and include (remove then add device) via the panel but still recognised as a SM103
Does anyone know what to do?
UPDATE:
This seems a problem that others on other platforms also have experienced. No solution found anywhere. However I have modified the “manufacturer_specific.xml” in /srv/hass/hass_venv/lib/python3.4/site-packages/libopenzwave-0.3.1-py3.4-linux-armv7l.egg/config to trick openZwave. It now loads the HSM02.xml instead of the HS103. And also shows up in HASS. However I have no idea if this will have any other negative site effects. One small one I have noticed anyway; It does not pass the complete name of the sensor to HASS.
