OpenZWave unavailable entities
I switched over to OpenZWave and have come to a road block. All of my devices show up, but show up as ‘unavailable’. They show on the front end, and in config>integration>devices and >entities.
I have a small network of 8 devices that I am ok to restart from scratch.
The ozwdaemon UI (HASS Ingress) does not list any devices - the windows show, but are empty.
The Hass UI shows “Network Starting” and “Connecting to MQTT” (has been this way for a long time so something is hung).
I have restarted MQTT, OpenZWave, and HASS, with no luck.
Any recommendations are appreciated.
mqtt log: if it helps - not sure what this is.
1608263150: Socket error on client zwave, disconnecting.
1608263152: New connection from 172.30.33.1 on port 1883.
1608263152: New client connected from 172.30.33.1 as mosq-oeHUjJA07vIHVR5Wz5 (p2, c1, k60, u’addons’).
1608263152: Client mosq-oeHUjJA07vIHVR5Wz5 disconnected.
1608263154: New connection from 172.30.33.1 on port 1883.
1608263154: New client connected from 172.30.33.1 as mosq-qgsnThK52gE61nRYWr (p2, c1, k60, u’addons’).
1608263154: Client mosq-qgsnThK52gE61nRYWr disconnected.
1608263163: New connection from 172.30.33.1 on port 1883.
1608263163: New client connected from 172.30.33.1 as mosq-bHAPluB195Ux1hrAST (p2, c1, k60, u’addons’).
1608263163: Client mosq-bHAPluB195Ux1hrAST disconnected.
1608263165: New connection from 172.30.33.1 on port 1883.
1608263165: New bridge connected from 172.30.33.1 as zwave (p2, c1, k60, u’addons’).
OpenZWave log:
[20201217 22:46:12.941 EST] [ozw.library] [info]: Info - Node: 255 Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
[20201217 22:46:12.941 EST] [ozw.library] [info]: Info - Node: 255 Encrypted Flag is 0
[20201217 22:46:13.942 EST] [ozw.library] [critical]: Error - Node: 255 ERROR: Dropping command, expected response not received after 1 attempt(s). Command: “FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9”
[20201217 22:46:13.944 EST] [ozw.library] [debug]: Detail - Node: 255 Removing current message
[20201217 22:46:13.945 EST] [ozw.library] [debug]: Detail - Node: 255 Notification: Notification - TimeOut
[20201217 22:46:13.946 EST] [ozw.notifications] [debug]: Notification pvt_ozwNotification NotificationTypes::Notification_Code_MsgTimeout Thread: 0x76f30558
[20201217 22:46:13.948 EST] [ozw.mqtt.publisher] [debug]: Publishing Event ozwNotification
1608263185: New connection from 172.30.32.1 on port 1883.
1608263185: New client connected from 172.30.32.1 as 4bnaIellfUPkg9L5o0TH2a (p2, c1, k60, u’homeassistant’).
I rebooted my RPi and now have front end control of the entities.
Also, the ozwdaemon UI (HASS Ingress) window is no longer empty. I don’t know what cleared, but rebooting helped.
I still see this in the MQTT Log
1608301488: New client connected from 172.30.33.1 as mosq-0mUBEoocX3FBrT7ieN (p2, c1, k60, u’addons’). 1608301488: Client mosq-0mUBEoocX3FBrT7ieN disconnected.
and in the OZW log, I don’t see the node 255 (which seems to be an error). Mostly correct looking communications. Some errors such as
[20201218 10:57:17.200 EST] [ozw.library] [critical]: Error - Node: 5 ERROR: Dropping command, expected response not received after 1 attempt(s). Command: “SwitchBinaryCmd_Get (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x25, 0x02, 0x25, 0xd0, 0x30”
