Opower reporting nothing from PG&E after 7 days
Installed Opower 7 days ago and expected a lag until things got caught up. 7 days later I still have no data from PG&E. I’ve logged in correctly and successfully gotten past the TFA, but nary a watt or therm comes my way.
I don’t see anything obvious in the logs.
Suggestions?
Is it working? i’m interested in getting my gas and electric Usage from PG&E.
https://www.reddit.com/r/homeassistant/s/2zfh4mqr9u
Unfortunately not. It prompts me to reauthenticate every few days and says authentication is successful but no data, no log entries, no indication of what is happening.
@Paddy707 your link to reddit took me to https://github.com/home-assistant/core/issues/152672 which seems to indicate that the problem was fixed but reading between the lines it also seems to suggest that there are still possible issues. I can image that it’s a difficult thing to try to debug MFA if you don’t have access to an account that requires it.
I did get an Emporia Vue for Christmas but haven’t yet found the time to set it up. I guess I’m going to need to do that sooner than later to get at the data that I want.
