Option to change integration IP-address after "pairing"
currently there is no way to change the IP-adress after an integration has been added to HA. when it comes to a change of IP-adress at the integration hardware, you have to kill and reconnect the integration. in most cases all entities and settings are lost.
maybe it is possible, to add an option, where we can edit the IP-adress of the integration and all the settings are saved …
This is done on a per integration basis. Some allow full re-configuration, others have basically nothing.
You need to specify which integration you want this for.
i see. i need ist for nibe heatpump integration. but it would be a nice thing, if this were a core functionality, all integrations could use …
That’s just it. The option is there. It is up to the integration developer to implement it.
may i ask for your help - i am struggeling to make this feature-request to the team of the nibe-integration - how do i do that?
If you mean this one:
You have already done it. This is the place for core integration feature requests.
