"options" for sensor device_class: enum
I’m trying to set up a sensor with a couple of strings as available states. The documentation says that I can use device_class: enum to do this, using options to define the possible states:
SensorDeviceClass.ENUM: The sensor has a limited set of (non-numeric) states. The options property must be set to a list of possible states when using this device class.
The problem I have is that I’m not sure how to specify the options. My sensor currently looks like this:
  - sensor:
      - name: Our House Consumption W or kW
        unique_id: our_house_consumption_w_or_kw
        state: >
          {% if states('sensor.myenergi_our_house_home_consumption')|float(1) < 1000 %}
            "W"
          {% else %}
            "kW"
          {% endif %}
        device_class: enum
If I put options at the same level as device_class then Studio Code Server tells me Property options is not allowed. But if I try to indent it from device_class then it sees it as continuation of enum and complains that I have to choose a correct device_class.
If anyone’s able to give me an example of how to use enum to define a list of possible states for a sensor, please, that would be great. I haven’t been able to find anything on this forum, or more widely.
Yeah, is super confusing.
'options' is an invalid option for 'template'
Options is an attribute. Example:
template:
  - sensor:
    - unique_id: thisorthat
      name: "This or That"
      device_class: enum
      state: "This"
      attributes:
        options: "{{ ['This', 'That'] }}"
Unfortunately, this does NOT work with RESTful sensor. This is an example what I’m trying to achieve but the configuration is invalid (‘attributes’ is an invalid option for ‘rest’, check: rest->0->sensor->2->attributes). Any solution to this? Thank you.
rest:
  - authentication: basic
    scan_interval: 60
    resource: https://...
      - name: "EcoVolter Charging Status"
        unique_id: sensor.ecovolter.charging_status
        value_template: '{{ value_json.chargingStatus }}'
        device_class: enum
        attributes:
          options: "{{ ['INIT', 'IDLE', 'CONNECTED', 'CHARGING', 'CHARGING_WITH_VENTILATION', 'CONTROL_PILOT_ERROR', 'ERROR'] }}"
