Hi i would like to test for 2 entities states in an if statemente in a lambda call:
esphome:
on_boot:
priority: -200
then:
- switch.turn_on: "${upper_devicename}_led"
- delay: 10s
- lambda: |-
if(id(wake_esp).state) {
id(dsleep1).prevent_deep_sleep();
if(id(wakelocal).state) {
Instead of 2 separated if statements, is it possible to combine both in same if with an “or” condition?
Since you don’t know any C++ why not just stick to using YAML?
if:
any:
- binary_sensor.is_on: wake_esp
- binary_sensor.is_on: wakelocal
then:
deep_sleep.prevent: dsleep1
Because all examples i saw are using lamdas. This is why i was thinking that IF statement could not be used in board “on_boot:” section.
So i will change it to yaml.
So the correct C++ sintax should be:
esphome:
on_boot:
priority: -200
then:
- delay: 10s
- lambda: |-
if(id(wake_esp).state || id(wakelocal).state)) {
I have coded it in Yaml:
if:
any:
then:
But i get this error:
Duplicate key "binary_sensor.is_on"
in "/config/esphome/espcorella.yaml", line 55, column 9
NOTE: Previous declaration here:
in "/config/esphome/espcorella.yaml", line 54, column 9
It compiles nicely
on_boot:
priority: -200
then:
- delay: 10s
- lambda: |-
if(id(wake_esp).state || id(wakelocal).state) {
Karosm
(Karosm)
April 28, 2025, 8:54am
8
You’re welcome.
I think the correct form for any would be
any:
