I just installed this weekend HA.
I’m busy migrating from Homey.
I use node_RED as tool.
And did set up a ssl connection true DuckDNS as dns provider.
It was working fine.
I figured out how to send TTS to my google home.
It didn’t work until I changed :
http:
base_url: https://mydns.duckdns.org:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
into:
http:
base_url: https://edwardha.duckdns.org
(without 8123 at the end of the url)
at DuckDNS config I do have:
lets_encrypt:
accept_terms: true
certfile: fullchain.pem
keyfile: privkey.pem
token: mytoken
domains:
mydns.duckdns.org
seconds: 300
(the dot before mydns.duckdns.org is a minus)
TTS is working fine then, but I’m not able to login outsite my local network anymore.
I’m using duckDNS as dns provider.
And did forward a port into my router
What to do to have and TTS and external login both working?
Thanks in advange
