Oral B BT proxy connection
I tried to set up an ESP32 as proxy for the toothbrush.
I used the config as in documentations with both proxy, active connection and BLE tracker but it doesn’t get a better signal strength.
When I place it right next to the ESP I get -80 db.
When I walk in the living room where the Pi is I get a much better value, like -50.
Do I need to disable it on the pi?
You could try this component instead.
That is part of the documentations of proxy
Bluetooth Proxy — ESPHome
I use this:
esphome:
  friendly_name: BT_proxy
esp32:
  board: esp32dev
  framework:
    type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "9HpYqmToQ+6Tf+5S80Jtx8egEXYBQIzSjXGBJxw1Ekg="
ota:
  - platform: esphome
    password: "ca97250089504e08f622a9b0c0ae4a1a"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Bt-Proxy Fallback Hotspot"
    password: "6IQqYoKuZvv8"
captive_portal:
esp32_ble_tracker:
  scan_parameters:
    interval: 1100ms
    window: 1100ms
    active: true
bluetooth_proxy:
  active: true
I don’t want to set up a tracker for it in ESP-Home since it will create duplicate entities.
I can’t remember how the Oral-B works, but if it is a standard BT connection then it is 1-to-1.
If it is a BT or BLE broadcast then it should be catches by all receivers.
I’m quite sure it broadcasts to anyone since I have not added it to the integration and I can see neighbours toothbrushes.
I’m thinking the ESP might be defect?
I will try some more when I get home and see if I somehow can make it connect to the proxy
My neighbours toothbrush has the strongest BLE signal in my house :angry:
Maybe I should hack it… What features they have?
Remove these two lines from your config
    interval: 1100ms
    window: 1100ms
They are for a wired Ethernet connection, it is in the documentation but usually missed.
I believe this worked.
But it still has very poor reception.
