Orange Light Theme -- JuanMTech
A light mode theme with an orange accent color
Screenshots
1. Desktop
2. Mobile
Preparation
  1. Make sure that under the configuration.yaml file you have the following:
frontend:
  themes: !include_dir_merge_named themes
  1. Under the Home Assistant Config folder, create a new folder named themes
  2. Restart Home assistant to apply the changes.
HACS installation
  1. Go into the Community Store (HACS)
  2. Search for Google Dark Theme
  3. Open the theme
  4. Press Install
Manual installation
  1. In the Home assistant themes folder, create a file named orange_light.yaml
  2. In this GitHub repo, go into the themes folder, open the orange_light.yaml file and copy the content
  3. Paste the content in the orange_light.yaml file created under your Home Assistant themes folder
Enable theme
  1. Open your Home Assistant Profile
  2. Under, Themes, select the new Orange Light Theme
Custom Header settings
When using the Custom Header plugin, add the following to make sure that the header matches the theme.
custom_header:
  compact_mode: true
  background: var(--app-header-background-color)
  elements_color: var(--app-header-text-color)
  active_tab_color: var(--state-icon-active-color)
  tab_indicator_color: var(--state-icon-active-color)
Subscribe to YouTube channel
Buy me a coffee
Become a Patron
