Let’s say I want an automation to happen, but I only want that automation to happen if the order of events are realized.
Example:
I arrive at home (trigger 1).
I open the front door (trigger 2).
= specific automation, contingent upon this sequence within a given time frame.
I open the mailbox (trigger 2).
I open the gate (trigger 3).
I open the back door (trigger 4).
= specific automation, contingent upon this sequence within a given timeframe.
These are all automations that would happen as a result of a pattern of behaviors. If the entire sequence was interrupted by a new trigger or detected state (i.e., left the mailbox open) then the automation might be different because not all of the triggers were satisfied within a specific period of time…etc.
Is this possible without extremely difficult NodeRED wiring and conditions and variables, etc.?
Another example:
I have 3 lights in a hallway all independently controlled. I have 3 motions sensors in the hallway. The order in which the sensors are triggered within a period of time would determine the direction of the lighting as I walk through the hallway.
