Ordinamento plance
Hello everyone, there is probably a way to move the order of the planks on the left part of HA. I tried to look but I found nothing. I would like to put in a stable order by me the planks
If you mean the sidebar:
  • Press and hold on the 3 Bars or where it says “Home Assistant” on the upper left
  • Stop pressing and the ordering panel pops up - click and drag, add, remove
I’m not sure what OS level you need to be at for that to be accessed
Than you !!!
Beats “press hamburger” which I see in a lot of documentation that appears to be hastily assembled.
“Three horizontal menu bar symbol” seems a mouthful to describe a menu selector icon.
Sometimes we forget that “press, hold and move” is often undocumented and assumed and often implemented differently with varying results, even within the same software package.
But is your solution documented or have you discovered it yourself?
