I have a Home Assistant OS installed on a raspberry pie using tail scale. It’s a raspberry pie three with one gigabyte. Once a day a monitor notices the tail scale connection has been lost to the Home Assistant. The HA still seems to be operating locally ok. I have monitored the hardware memory usage nd it shows around 62% with a slight drift upwards but it doesn’t seem to go above 80% without falling back down again , looking at the supervisor logs you can see that the Tailscale has been killed by the OS . from what I think I can deduce it implies that the supervisor found a out of memory issue and killed Tailscale. It’s odd that It always kills tail scale. It’s odd that the memory doesn’t seem to grow up the only way to fix the problem is to reboot the raspberry pie reload in the Home assistant doesn’t correct it other than that everything is working fine so at the moment I have a monitor going and when it spots the Home Assistant connection has dropped off from within tail scale it ping me a notification and I power off and on the raspberry pie which is not ideal as you can imagine. this morning it behaved slightly differently in failing it failed just before 9 am before I rebooted it. I attempted to get hold of the host log and while it was loading the whole Home Assistant locked up I rebooted trying to get hold of the whole log again and it locked again and I rebooted. I’ve attached the supervisor log for I think the complete period anyhow will be greatly appreciated thank you.
I don’t seem to be able to attach the log. I will keep trying.
Here is 0ne section
2026-09-09 09:19:58.447 INFO (MainThread) [supervisor.store.git] Loading app /data/apps/core repository
2026-09-09 09:19:58.448 INFO (MainThread) [supervisor.store.git] Loading app /data/apps/git/a0d7b954 repository
2026-09-09 09:20:03.145 INFO (MainThread) [supervisor.store] Loading apps from store: 88 all - 88 new - 0 remove
2026-09-09 09:20:03.279 INFO (MainThread) [supervisor.apps.manager] Found 4 installed apps
2026-09-09 09:20:03.424 INFO (MainThread) [supervisor.docker.interface] Attaching to Package aarch64-addon-get · GitHub with version 1.3.1
2026-09-09 09:20:03.447 INFO (MainThread) [supervisor.docker.interface] Attaching to Package tailscale · GitHub with version 0.29.0
2026-09-09 09:20:03.456 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-configurator with version 6.1.0
2026-09-09 09:20:03.462 ERROR (MainThread) [supervisor.apps.app] App Tailscale exited with non-zero exit code 255
2026-09-09 09:20:03.463 ERROR (MainThread) [supervisor.apps.app] App File editor exited with non-zero exit code 255
2026-09-09 09:20:03.468 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-ssh with version 10.4.0
2026-09-09 09:20:03.482 ERROR (MainThread) [supervisor.apps.app] App Terminal & SSH exited with non-zero exit code 255
2026-09-09 09:20:03.831 INFO (MainThread) [supervisor.backups.manager] Found 3 backup files
2026-09-09 09:20:03.894 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
2026-09-09 09:20:03.895 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
2026-09-09 09:20:03.895 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
2026-09-09 09:20:03.895 INFO (MainThread) [supervisor.resolution.checks.base] Run check for duplicate_os_installation/system
And another earlier one
2026-09-09 08:32:32.841 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2026-09-09 08:32:32.842 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2026-09-09 08:35:02.217 INFO (MainThread) [supervisor.backups.manager] Found 3 backup files
2026-09-09 08:57:23.541 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session fb4e044f3523b02e061256397cbcde31e9586fe6f3f50479ae901aefb94d04bca28cbaec51a2351415d458e90c576c3292be45c99e0299b0af03811b8225c721
2026-09-09 08:57:23.576 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session fb4e044f3523b02e061256397cbcde31e9586fe6f3f50479ae901aefb94d04bca28cbaec51a2351415d458e90c576c3292be45c99e0299b0af03811b8225c721
2026-09-09 08:57:25.079 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session fb4e044f3523b02e061256397cbcde31e9586fe6f3f50479ae901aefb94d04bca28cbaec51a2351415d458e90c576c3292be45c99e0299b0af03811b8225c721
2026-09-09 08:57:25.115 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session fb4e044f3523b02e061256397cbcde31e9586fe6f3f50479ae901aefb94d04bca28cbaec51a2351415d458e90c576c3292be45c99e0299b0af03811b8225c721
2026-09-09 08:57:26.117 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session fb4e044f3523b02e061256397cbcde31e9586fe6f3f50479ae901aefb94d04bca28cbaec51a2351415d458e90c576c3292be45c99e0299b0af03811b8225c721
2026-09-09 08:57:26.151 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session fb4e044f3523b02e061256397cbcde31e9586fe6f3f50479ae901aefb94d04bca28cbaec51a2351415d458e90c576c3292be45c99e0299b0af03811b8225c721
2026-09-09 08:58:20.026 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session fb4e044f3523b02e061256397cbcde31e9586fe6f3f50479ae901aefb94d04bca28cbaec51a2351415d458e90c576c3292be45c99e0299b0af03811b8225c721
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[08:10:05] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully st
I also have 2026.8. I did try to go to 9 but it wouldn’t install. I’ve put that to one side for now
The Pi3 is no longer recommended hardware.
- You should consider reading How to help us help you - or How to ask a good question
- like the others said: Pi3 is unsupported/unrecommended Hardware and if I were you Id either:
superlazy and inefficiently: Buy a PI5 and burn alot of Money
OR get something like a NUC/a HP EliteDesk 800 G2 Mini (or any other reasonable Thin Clients)
