I have been trying to upgrade from OS 17.2 to 17.3 on HA Yellow and getting the following messages for a couple of days
I have a feeling this has happened in the past, and it eventually resolved itself
I eventually resolved this as i documented all the steps i performed so posting here in case it is useful to others or some one can tell me why the supervisor has no internet access, and if i can resolve this
Failed to perform the action update/install. Error updating Home Assistant Operating System: 'OSManager.update' blocked from execution, no supervisor internet connection
tried from command line and similar results
ha os upgrade
Processing... Done.
Error: 'OSManager.update' blocked from execution, no supervisor internet connection
tried all suggestions in these two
Ok... where did the apps / add ons option go - #10 by georgelza
Supervisor internet false - #15 by Chykan
rebooted and powered off and rebooted
disabled wifi ( as I may have enabled / configured this when trying to get the matter over thread recently )
ha supervisor repair
ha supervisor restart
nmcli g status
STATE CONNECTIVITY WIFI-HW WIFI WWAN-HW WWAN METERED
connected full enabled disabled missing enabled no (guessed)
nmcli n connectivity
full
curl -v http://checkonline.home-assistant.io/online.txt
> GET /online.txt HTTP/1.1
> Host: checkonline.home-assistant.io
> User-Agent: curl/8.18.0
> Accept: */*
< HTTP/1.1 200 OK
NetworkManager is online
ha network info
docker:
address: 172.30.32.0/23
dns: 172.30.32.3
gateway: 172.30.32.1
interface: hassio
host_internet: true
supervisor_internet: false
eventually worked out on of the commands in the links was incorrect / incomplete and this was the correct one
ha jobs options --ignore-conditions internet_host
Command completed successfully.
# ha jobs reset
Processing... Done.
# ha supervisor restart
ha jobs info
ignore_conditions: []
jobs: []
# ha os upgrade
Processing... Done.
System rebooted then and installed the upgrade !
