OSAM - Open Sensor Alert Manager - Advanced Contact Sensor Monitoring
OSAM transforms your basic contact sensors into intelligent monitoring systems with powerful notification features. It handles everything from simple window-open reminders to complex security monitoring with escalations, temperature checks, and multi-language support. Whether you need energy-saving alerts or critical security warnings that override quiet hours, OSAM adapts to your needs without requiring any coding skills.
:pushpin: TL;DR - Quick Overview
OSAM is a powerful blueprint for monitoring doors and windows with smart notifications, escalation warnings, and extensive customization.
Key Features:
  • :bell: Smart repeat notifications with customizable intervals
  • :rotating_light: Escalation system for critical alerts (after X notifications)
  • :crescent_moon: Quiet time with separate workday/weekend schedules (optional)
  • :pause_button: Counter-based snooze function
  • :thermometer: Temperature-based alerts (only notify when cold)
  • :earth_africa: Multi-language support (DE/EN/FR/IT) - use <opened_duration_en> in templates
  • :bar_chart: Daily notification limits
  • :dart: Custom actions on first/repeat/escalation/resolved
  • :floppy_disk: JSON storage for unlimited sensors
Perfect for: Energy saving alerts, security monitoring, door left open reminders, freezer door warnings.
Setup time: 5-10 minutes (create 2 helper entities, import blueprint, configure automation)
:star2: Introduction
OSAM (Open Sensor Alert Manager) is a comprehensive blueprint for monitoring contact sensors (doors/windows) with advanced features like escalation management, quiet time, temperature checks, and much more.
I created this blueprint because I was tired of getting spammed by door/window notifications or missing critical alerts. OSAM gives you complete control over when, how, and how often you get notified.
:package: Installation
Or manually:
https://github.com/thezeus123/OSAM/
:sparkles: Key Features
:bell: Smart Notification System
  • Flexible repeat intervals - Set how often to remind you
  • Multi-language support - Duration in German, English, French, Italian
  • Custom notification scripts - Use your own notification system
  • Message templates - Fully customizable with variables
:rotating_light: Escalation Management
  • Critical warnings after X notifications
  • Separate devices for escalations (e.g., SMS for critical alerts)
  • Override quiet time for emergencies
  • Higher volume for Alexa escalations
  • Ignores daily limits but still tracks count
:crescent_moon: Quiet Time (Optional)
  • Separate schedules for workdays and weekends
  • Workday sensor integration for automatic detection
  • Completely optional - Disable for 24/7 monitoring
  • Reminder notification when quiet time ends
:pause_button: Snooze Function
  • Counter-based - Suppress X notifications instead of time-based
  • Automatic disable when counter reaches zero
  • Per-automation control with helper boolean
:thermometer: Temperature Integration
  • Conditional notifications - Only notify when cold outside
  • Configurable threshold - Set your own temperature limit
  • Perfect for “window open when it’s freezing” alerts
:bar_chart: Daily Limits
  • Cap notifications to prevent spam
  • Automatic reset at midnight
  • Escalations ignore limits (but count towards total)
:dart: Custom Actions
Execute automations at key points:
  • First notification sent
  • Repeat notification sent
  • Escalation triggered
  • Issue resolved
:floppy_disk: JSON Storage
  • Unlimited sensors with single input_text entity
  • Persistent data across restarts
  • Tracks: counter, first_opened, escalation_sent, snooze status
:dart: Real-World Examples
Example 1: Front Door Security
Detection Grace Period: 2 minutes
Repeat Interval: 10 minutes
Escalation: After 6 notifications
Escalation Override Quiet Time: Yes
Why: Critical security, escalate if ignored, alert even at night
Example 2: Bedroom Window (Energy Saving)
Detection Grace Period: 10 minutes
Enable Temperature Check: Yes
Temperature Threshold: 10°C
Quiet Time: 22:00 - 07:00
Why: Only care when it’s cold, don’t bug me at night
Example 3: Garage Door
Detection Grace Period: 30 minutes
Daily Limit: 5 notifications
Repeat Interval: 60 minutes
Why: Sometimes intentionally left open, don’t spam
Example 4: Freezer Door
Detection Grace Period: 1 minute
Escalation: After 3 notifications
Escalation Volume: 100%
Custom Action (Escalation): Flash kitchen lights
Why: Critical! Food spoiling risk, immediate action needed
:wrench: Setup Requirements
Required Helpers (per automation)
1. Input Boolean (for repeat logic)
Settings → Devices & Services → Helpers → Create Helper → Toggle
2. Input Text (for JSON storage)
Settings → Devices & Services → Helpers → Create Helper → Text
Maximum length: 255 (default is fine!)
Important: Create one JSON storage per sensor (recommended). The default 255 character limit via GUI is sufficient. Only use shared storage (10000+ chars) if you have many sensors and want to manage them in one entity.
Optional Helpers
3. Input Boolean (for snooze)
:open_book: Configuration Guide
Available Variables in Templates
Use these variables in your notification titles and messages:
Variable Description Example Output
<friendly_name> Sensor display name “Front Door”
<opened_duration> Time open (German) “2 Stunden und 15 Minuten”
<counter> Notification count “8”
<counter_ordinal> Ordinal (German) “achte”
:earth_africa: Multi-Language: Use Language-Specific Variables!
Want English notifications? Just use <opened_duration_en> instead of <opened_duration>!
Duration Variable Language Example
<opened_duration_de> German “2 Stunden und 15 Minuten”
<opened_duration_en> English “2 hours and 15 minutes”
<opened_duration_fr> French “2 heures et 15 minutes”
<opened_duration_it> Italian “2 ore e 15 minuti”
Ordinal Variable Language Example (8th)
<counter_ordinal_de> German “achte”
<counter_ordinal_en> English “eighth”
<counter_ordinal_fr> French “huitième”
<counter_ordinal_it> Italian “ottava”
Example - English notifications:
notification_title: "WARNING: <friendly_name> is open!"
notification_msg_first: |
  <friendly_name> has been open for <opened_duration_en>!
  Please check if this is intentional.
notification_msg_repeat: |
  REMINDER: <friendly_name> is still open!
  Duration: <opened_duration_en>
  This is the <counter_ordinal_en> reminder.
What you’ll see:
WARNING: Front Door is open!
Front Door has been open for 2 hours and 15 minutes!
REMINDER: Front Door is still open!
Duration: 2 hours and 15 minutes
This is the eighth reminder.
No blueprint editing needed! Just use the language variable you want in your templates.
:open_book: Full guide: LOCALIZATION.md
Example message template:
WARNING: <friendly_name> has been open!
Duration: <opened_duration>
This is notification #<counter> (the <counter_ordinal>)
Output:
WARNING: Front Door has been open!
This is notification #8 (the eighth)
:bug: Troubleshooting
No notifications received?
  1. Enable Debug Mode in blueprint
  2. Check Settings → System → Logs
  3. Filter by osam.your_sensor_name
  4. Look for: quiet time status, temperature check, daily limit
JSON Storage errors?
  • Using one storage per sensor? Default 255 chars is enough!
  • Using shared storage? Increase to 10000+ in configuration.yaml
  • Check entity exists: input_text.osam_[sensor]_json
  • View state to see stored JSON data
  • Best practice: One storage per sensor (simpler!)
Escalations not working?
  • Check Escalation After Count is reached
  • Verify Enable Escalation is checked
  • If using Override Quiet Time, check it’s enabled
  • Look for ESCALATION triggered in logs (Debug Mode)
:memo: Version History
v3.12.1 (Current) - 2025-10-24
  • :bug: Fixed double notifications (escalation + regular)
  • :bug: Fixed YAML parsing errors from emoji characters
  • :sparkles: Escalations now ignore daily limits properly
v3.12.0 - 2025-10-24
  • :sparkles: Optional escalation repeat
v3.11.0 - 2025-10-20
  • :sparkles: Optional quiet time (24/7 mode)
  • :sparkles: Count-based escalation
  • :sparkles: Escalation override quiet time
  • :sparkles: Separate escalation volume
Full Changelog
:handshake: Contributing
Found a bug? Have an idea?
:electric_plug: Notification System
OSAM supports flexible notification delivery:
Built-in (Default)
Uses Home Assistant’s persistent_notification - no setup needed!
Custom Scripts (Optional)
Create your own notification script to:
  • :white_check_mark: Route to multiple devices (mobile, Alexa, Telegram)
  • :white_check_mark: Add rich notifications with action buttons
  • :white_check_mark: Customize based on time/priority
  • :white_check_mark: Integrate with third-party services
Example:
notification_script: "script.zentrale_benachrichtigung"
notification_delete_script: "script.benachrichtigung_loschen"
Your script receives: title, message, devices, priority, volume, tag
:open_book: Full guide: NOTIFICATION_SCRIPTS.md
:star: Show Your Support
If you find OSAM useful:
  • Give it a :star: on GitHub
  • Share with the community
  • Submit feature requests
:link: Links
OSAM = Open Sensor Alert Manager
Questions? Ask away! :point_down:
Your AI didn’t get the link right… Please double check EVERYTHING before re-pasting this stuff in here so us users are not affected…
This is weird:
  • Your github changelogs have the same dates but 2024 instead of 2025
  • It looks like a very active project with different releases since 2023, but it’s just one commit
  • …from one person with a fairly new account
  • content seems sus as well
Is this just someone using AI to generate code including this forum post? Or is something fishy going on…
