OSRAM Lightify bulbs not being detected
I’m moving some of my devices over from smartthings. I cant get HA to detect my 2 osram lightify bulbs. They get detected pretty quickly in smartthings but nothing on HA. Here are the logs from zigbee, not sure if they are helpful. I did just add another zigbee lightbulb to HA without issues.
[0x0000:zdo] ZDO request ZDOCmd.Mgmt_Permit_Joining_req: [60, <Bool.false: 0>]
[0x4e62:1:0x0001] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=24 command_id=Command.Report_Attributes>
[0x4e62:1:0x0001] ZCL request 0x000a: [[Attribute(attrid=32, value=<TypeValue type=uint8_t, value=25>)]]
[0x4e62:1:0x0001] Attribute report received: battery_voltage=25
[0xecec:5:0x0500] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=230 command_id=0>
[0xecec:5:0x0500] ZCL request 0x0000: [<ZoneStatus.Restore_reports|Alarm_1: 33>, <bitmap8.0: 0>, 0, 0]
[0xecec:5:0x0500] No handler for cluster command 0
[0xECEC:5:0x0500]: Updated alarm state: ZoneStatus.Alarm_1
[0xecec:5:0x0500] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=231 command_id=0>
[0xecec:5:0x0500] ZCL request 0x0000: [<ZoneStatus.Restore_reports: 32>, <bitmap8.0: 0>, 0, 0]
[0xECEC:5:0x0500]: Updated alarm state: ZoneStatus.0
[0x4e62:1:0x0402] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=False> manufacturer=None tsn=25 command_id=Command.Report_Attributes>
[0x4e62:1:0x0402] ZCL request 0x000a: [[Attribute(attrid=0, value=<TypeValue type=int16s, value=1100>)]]
[0x4e62:1:0x0402] Attribute report received: measured_value=1100
Any suggestions?
