Osram lightify LED extension alternative
Hi, I got 3 osram lightify led strips. I discovered that I can use 4 meters led strip on one controller, but like other osram equipment the extensions are expensive.
I was thinking to use 2 x 2 m orgininal osram strip on one controller and buying a cheep 4 m led strip for the other.
I don’t know much about led there is so many, I can see the osram is +rgwb ordered.
I found the extension product data sheet: https://www.osram.com/osram_com/products/led-technology/indoor-led-luminaires/flexible-led-modules/lightify-flex-rgbw/
I took a look at the controller. It’s 12 v and says max 20 W.
I see that 2 m of extension led is 18 W, So I guess this in inposible… or could an amplifyer be added?
