OTA automatic firmware update issue
Hello!
I have 5 esp32 working just fine with esphome.
There is an issue with the latest one, not updating the firmware when I send the service command update.install via an automation in HA.
In fact, on this device, the entity update.aaa_firmware is in the diagnostic category, which is read-only, instead of the config category like the 4 others.
I have not clue why on this specific esp32 it happens. I have always the same basic config code on all devices.
Any thoughts?
Thanks in advance.
the yaml code:
esphome:
  friendly_name: Solar Monitor
  # Run script on boot to decide deep sleep timing
  on_boot:
    - priority: -100
      then:
        - script.execute: check_current
substitutions:
  device_name: my-device
esp32:
  board: esp32dev
  framework:
    type: arduino
logger:
  baud_rate: 115200
  level: DEBUG
api:
  encryption:
    key: "REDACTED"  # Secure API connection key
ota:
  - platform: esphome
    password: "REDACTED"  # OTA update password
wifi:
  ssid: !secret wifi_ssid
  power_save_mode: LIGHT  # Light sleep to reduce power usage
i2c:
  sda: GPIO21
  scl: GPIO22
  scan: true  # Auto-detect I2C devices
  - platform: ina219
    address: 0x40
    shunt_resistance: 0.1Ω
    max_voltage: 6.0V
    max_current: 3.2A
    update_interval: 5s
    power:
    bus_voltage:
    shunt_voltage:
    current:
      unit_of_measurement: "A"
      accuracy_decimals: 6
  - platform: adc
    pin: GPIO32
    unit_of_measurement: "V"
    accuracy_decimals: 2
    update_interval: 5s
    attenuation: 11db
    filters:
      - multiply: 1.272  # Voltage divider calibration
  - platform: wifi_signal
    name: "${device_name} WiFi Signal"
    update_interval: 5s
binary_sensor:
  - platform: status
    name: "Device Status"  # Shows if ESP is online
  - platform: homeassistant
    entity_id: input_boolean.disable_deep_sleep
    on_release:
      then:
        - script.execute: check_current  # Re-evaluate sleep on input change
text_sensor:
  - platform: wifi_info
    ip_address:
    ssid:
    mac_address:
script:
  - id: check_current
    mode: queued
    then:
      - wait_until:
          condition:
            api.connected:
          timeout: 10s
      - delay: 2s
      - if:
          condition:
            lambda: |-
              return !id(disable_sleep).state;
          then:
            - if:
                condition:
                  lambda: 'return id(solar_current).state < 0.0;'  # Panel current is negative (night)
                then:
                  - deep_sleep.enter:
                      sleep_duration: 600000ms  # 10 minutes
                else:
                  - deep_sleep.enter:
                      sleep_duration: 60000ms  # 1 minute
deep_sleep:
  id: deep_sleep_control  # Deep sleep controller
