OTBR add-on randomly stops
As the title says, everything works fine for a day or two, and then the OpenThread Border Router add-on simply stops. The Docker container exits, and the watchdog doesn’t seem to restart it.
Sometimes I see errors like this:
00:00:29.443 [W] P-RadioSpinel-: RCP failure detected
00:00:29.443 [C] P-RadioSpinel-: Too many rcp failures, exiting
00:00:29.443 [C] Platform------: RecoverFromRcpFailure() at radio_spinel.cpp:2063: Failure
[23:39:33] WARNING: motbr-agent exited with code 1 (by signal 0).
Other times, I get:
00:13:24.958 [W] P-RadioSpinel-: radio tx timeout
00:13:24.967 [C] P-RadioSpinel-: Failed to communicate with RCP - no response from RCP during initialization
00:13:24.967 [C] P-RadioSpinel-: This is not a bug and is typically due to a configuration error (wrong URL parameters) or a bad RCP image:
00:13:24.967 [C] P-RadioSpinel-: - Make sure RCP is running the correct firmware
00:13:24.967 [C] P-RadioSpinel-: - Double-check the config parameters passed as `RadioURL` input
00:13:24.967 [C] Platform------: HandleRcpTimeout() at radio_spinel.cpp:2013: RadioSpinelNoResponse
[09:30:17] WARNING: motbr-agent exited with code 6 (by signal 0).
If I manually start the add-on again, everything works normally.
Any ideas what could be causing this?
I’m using an SLZB-MR2 in dual mode, connected via PoE. Zigbee is completely stable, but Thread has this issue almost every day.
Hi!
I am getting the same error using a ZBT-2 (connected to a USB Cat extender) after a couple of days.
It seems that the ZBT-2 is hanging when this happens - I have to unplug and plug it in again.
Any help would be appreciated!
1d.02:10:43.659 [W] P-RadioSpinel-: radio tx timeout
1d.02:10:43.671 [C] P-RadioSpinel-: Failed to communicate with RCP - no response from RCP during initialization
1d.02:10:43.671 [C] P-RadioSpinel-: This is not a bug and typically due a config error (wrong URL parameters) or bad RCP image:
1d.02:10:43.671 [C] P-RadioSpinel-: - Make sure RCP is running the correct firmware
1d.02:10:43.671 [C] P-RadioSpinel-: - Double check the config parameters passed as RadioURL input
1d.02:10:43.671 [C] Platform------: HandleRcpTimeout() at radio_spinel.cpp:2013: RadioSpinelNoResponse
[09:53:41] WARNING: otbr-agent exited with code 6 (by signal 0).
Based on it working mostly and failing occasionally / randomly, I would look at hardware stability, specifically the USB Cat extender:
Either USB hub power drop or hub related issues. Plug it directly into host temporarily and try again and see if it stops
have similar issue every 10-20 days. I use SLZB-06 connected wia 0.5m USB 3.2 Gen 2 cable to my SBC.
2026-04-08 06:17:42.740
2026-04-08 06:17:42.664
07:37:41.459 [C] Platform------: HandleRcpTimeout() at radio_spinel.cpp:2013: RadioSpinelNoResponse
07:37:41.459 [C] P-RadioSpinel-: - Double check the config parameters passed as `RadioURL` input
07:37:41.459 [C] P-RadioSpinel-: - Make sure RCP is running the correct firmware
error
07:37:41.459 [C] P-RadioSpinel-: This is not a bug and typically due a config error (wrong URL parameters) or bad RCP image:
07:37:41.459 [C] P-RadioSpinel-: Failed to communicate with RCP - no response from RCP during initialization
The following extender has been working fine for the last 10 days:
LogiLink UA0267 USB 2.0 Cat.5 Extender, 50m, 1 Port Hub
Interestingly the 4-port version did not work (errors shown in my initial post). However, I had attached a second device to that extender, maybe power consumption was an issue.
