Out of Box Installation - not working
Hi all. Got an HA Green out of the box, trying to install it, but I fail badly.
After 1/2 day of trial and error, I am not able to move further than to following repeating log error(s):
2025-12-25 16:59:41.192 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag 2025.12.4.
2025-12-25 16:59:41.315 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/green-homeassistant:2025.12.4: 500 Server Error for http+docker://localhost/v1.51/images/create?tag=2025.12.4&fromImage=ghcr.io%2Fhome-assistant%2Fgreen-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io: Temporary failure in name resolution")
2025-12-25 16:59:41.316 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
2025-12-25 16:59:57.770 INFO (MainThread) [supervisor.plugins.dns] Restarting CoreDNS plugin
2025-12-25 16:59:57.778 INFO (SyncWorker_5) [supervisor.docker.manager] Restarting hassio_dns
I plugged into the console and started to learn the CLI commands, and was able to observe, that the network settings keep changing, IPV4 being as ready true/false randomly.
I changed the IP in my router to a static IP, which sometimes reflects also in the “ha network info” screen. And sometimes again not.
Received also the “low voltage” error, so installed a 2032 battery, just to be sure (however that meanwhile quite errodes the “out of the box” experience).
Thanks for help
Check your DNS settings, and you can also try another cable and / or another port.
Thanks, meanwhile tried to change the cable and that might have helped. Fingers crossed.
