Same here, not working:
Logger: homeassistant.config_entries
Quelle: config_entries.py:787
Erstmals aufgetreten: 10:53:48 (1 Vorkommnis)
Zuletzt protokolliert: 10:53:48
Error setting up entry Outdoor Environment for outdoor_environment
File "/usr/src/homeassistant/homeassistant/loader.py", line 1281, in _load_platform
cache[full_name] = self._import_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1313, in _import_platform
return importlib.import_module(f"{self.pkg_path}.{platform_name}")
File "/usr/src/homeassistant/homeassistant/util/loop.py", line 201, in protected_loop_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.14/importlib/__init__.py", line 88, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1398, in _gcd_import
File "<frozen importlib._bootstrap>", line 1371, in _find_and_load
File "<frozen importlib._bootstrap>", line 1342, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 938, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 759, in exec_module
File "<frozen importlib._bootstrap>", line 491, in _call_with_frames_removed
File "/config/custom_components/outdoor_environment/sensor.py", line 136, in <module>
device_class=SensorDeviceClass.CARBON_MONOXIDE,
AttributeError: type object 'SensorDeviceClass' has no attribute 'CARBON_MONOXIDE'
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 787, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File "/config/custom_components/outdoor_environment/__init__.py", line 74, in async_setup_entry
await hass.config_entries.async_forward_entry_setups(entry, PLATFORMS)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2727, in async_forward_entry_setups
await integration.async_get_platforms(platforms)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1194, in async_get_platforms
import_future.result()
File "/usr/src/homeassistant/homeassistant/loader.py", line 1182, in async_get_platforms
platforms.update(self._load_platforms(platform_names))
File "/usr/src/homeassistant/homeassistant/loader.py", line 1107, in _load_platforms
platform_name: self._load_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1301, in _load_platform
raise ImportError(
f"Exception importing {self.pkg_path}.{platform_name}"
) from err
ImportError: Exception importing custom_components.outdoor_environment.sensor
Logger: homeassistant.loader
Quelle: loader.py:1281
Erstmals aufgetreten: 10:53:48 (2 Vorkommnisse)
Unexpected exception importing platform custom_components.outdoor_environment.sensor
Logger: homeassistant.util.loop
Quelle: util/loop.py:137
Detected blocking call to import_module with args ('custom_components.outdoor_environment.sensor',) inside the event loop by custom integration 'outdoor_environment' at custom_components/outdoor_environment/__init__.py, line 74: await hass.config_entries.async_forward_entry_setups(entry, PLATFORMS) (offender: /usr/src/homeassistant/homeassistant/loader.py, line 1313: return importlib.import_module(f"{self.pkg_path}.{platform_name}")), please create a bug report at https://github.com/nuggetz/ha-outdoor-environment/issues For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#import_module Traceback (most recent call last): File "<frozen runpy>", line 198, in _run_module_as_main File "<frozen runpy>", line 88, in _run_code File "/usr/src/homeassistant/homeassistant/__main__.py", line 229, in <module> sys.exit(main()) File "/usr/src/homeassistant/homeassistant/__main__.py", line 215, in main exit_code = runner.run(runtime_conf) File "/usr/src/homeassistant/homeassistant/runner.py", line 289, in run return loop.run_until_complete(setup_and_run_hass(runtime_config)) File "/usr/local/lib/python3.14/asyncio/base_events.py", line 706, in run_until_complete self.run_forever() File "/usr/local/lib/python3.14/asyncio/base_events.py", line 677, in run_forever self._run_once() File "/usr/local/lib/python3.14/asyncio/base_events.py", line 2046, in _run_once handle._run() File "/usr/local/lib/python3.14/asyncio/events.py", line 94, in _run self._context.run(self._callback, *self._args) File "/usr/src/homeassistant/homeassistant/config_entries.py", line 955, in async_setup_locked await self.async_setup(hass, integration=integration) File "/usr/src/homeassistant/homeassistant/config_entries.py", line 694, in async_setup await self.__async_setup_with_context(hass, integration) File "/usr/src/homeassistant/homeassistant/config_entries.py", line 787, in __async_setup_with_context result = await component.async_setup_entry(hass, self) File "/config/custom_components/outdoor_environment/__init__.py", line 74, in async_setup_entry await hass.config_entries.async_forward_entry_setups(entry, PLATFORMS)
