Sorry everyone,
I decided to make my own thread on this instead of jumping on that old thread here.
Here is the old post talking about this:
I just did a test and created a template sensor called “123 Test” that is set to {{ 0 }}. I then created a filter that used this as input and set it to the same settings window side: 1 radius 0.5, precision 4
I change the settings from 0.1 to 1.0 in 0.1 increments
2025-03-31 14:56:10.533 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=0; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:55:11.696613-04:00>, new_state=<state sensor.123_test_sensor=0.1; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:56:10.531203-04:00>>
2025-03-31 14:56:10.534 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=0.1) -> 0.1
2025-03-31 14:56:13.127 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=0.1; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:56:10.531203-04:00>, new_state=<state sensor.123_test_sensor=0.2; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:56:13.126162-04:00>>
2025-03-31 14:56:13.127 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=0.2) -> 0.2
2025-03-31 14:56:15.595 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=0.2; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:56:13.126162-04:00>, new_state=<state sensor.123_test_sensor=0.3; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:56:15.592532-04:00>>
2025-03-31 14:56:15.596 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=0.3) -> 0.3
2025-03-31 14:56:17.854 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=0.3; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:56:15.592532-04:00>, new_state=<state sensor.123_test_sensor=0.4; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:56:17.849458-04:00>>
2025-03-31 14:56:17.854 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=0.4) -> 0.4
2025-03-31 14:56:20.270 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=0.4; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:56:17.849458-04:00>, new_state=<state sensor.123_test_sensor=0.5; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:56:20.267150-04:00>>
2025-03-31 14:56:20.271 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=0.5) -> 0.5
2025-03-31 14:56:22.546 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=0.5; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:56:20.267150-04:00>, new_state=<state sensor.123_test_sensor=0.6; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:56:22.545696-04:00>>
2025-03-31 14:56:22.546 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=0.6) -> 0.6
2025-03-31 14:56:25.271 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=0.6; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:56:22.545696-04:00>, new_state=<state sensor.123_test_sensor=0.7; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:56:25.261701-04:00>>
2025-03-31 14:56:25.272 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=0.7) -> 0.7
2025-03-31 14:56:27.649 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=0.7; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:56:25.261701-04:00>, new_state=<state sensor.123_test_sensor=0.8; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:56:27.646329-04:00>>
2025-03-31 14:56:27.650 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=0.8) -> 0.8
2025-03-31 14:56:30.583 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=0.8; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:56:27.646329-04:00>, new_state=<state sensor.123_test_sensor=0.9; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:56:30.580650-04:00>>
2025-03-31 14:56:30.584 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=0.9) -> 0.9
2025-03-31 14:56:36.982 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=0.9; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:56:30.580650-04:00>, new_state=<state sensor.123_test_sensor=1.0; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:56:36.980704-04:00>>
2025-03-31 14:56:36.983 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=1.0) -> 1.0
2025-03-31 14:57:29.321 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=1.0; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:56:36.980704-04:00>, new_state=<state sensor.123_test_sensor=5; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:57:29.318384-04:00>>
The filter works as expected
Then I change from 1.0 to 5.0
2025-03-31 14:57:29.322 DEBUG (MainThread) [homeassistant.components.filter.sensor] Outlier nr. 1 in sensor.123_test_sensor: 5.0
2025-03-31 14:57:29.323 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=5) -> 1.0
Then I changed the value back to 1.0
2025-03-31 14:57:34.743 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=5; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:57:29.318384-04:00>, new_state=<state sensor.123_test_sensor=1.0; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:57:34.740110-04:00>>
2025-03-31 14:57:34.744 DEBUG (MainThread) [homeassistant.components.filter.sensor] Outlier nr. 2 in sensor.123_test_sensor: 1.0
2025-03-31 14:57:34.745 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=1.0) -> 5.0
I then updated it from 1.0 → 1.6 by 0.1 increment
2025-03-31 14:57:37.599 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=1.0; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:57:34.740110-04:00>, new_state=<state sensor.123_test_sensor=1.1; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:57:37.596326-04:00>>
2025-03-31 14:57:37.599 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=1.1) -> 1.1
2025-03-31 14:57:40.681 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=1.1; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:57:37.596326-04:00>, new_state=<state sensor.123_test_sensor=1.2; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:57:40.678844-04:00>>
2025-03-31 14:57:40.682 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=1.2) -> 1.2
2025-03-31 14:57:43.450 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=1.2; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:57:40.678844-04:00>, new_state=<state sensor.123_test_sensor=1.3; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:57:43.445180-04:00>>
2025-03-31 14:57:43.457 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=1.3) -> 1.3
2025-03-31 14:57:46.610 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=1.3; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:57:43.445180-04:00>, new_state=<state sensor.123_test_sensor=1.4; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:57:46.608001-04:00>>
2025-03-31 14:57:46.611 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=1.4) -> 1.4
2025-03-31 14:57:49.098 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=1.4; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:57:46.608001-04:00>, new_state=<state sensor.123_test_sensor=1.5; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:57:49.095900-04:00>>
2025-03-31 14:57:49.099 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=1.5) -> 1.5
2025-03-31 14:57:52.597 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=1.5; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:57:49.095900-04:00>, new_state=<state sensor.123_test_sensor=1.6; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:57:52.597159-04:00>>
2025-03-31 14:57:52.598 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=1.6) -> 1.6
Again this works as expected
Then again I change it from 1.6 to 5.0
2025-03-31 14:57:57.115 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=1.6; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:57:52.597159-04:00>, new_state=<state sensor.123_test_sensor=5; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:57:57.112598-04:00>>
2025-03-31 14:57:57.116 DEBUG (MainThread) [homeassistant.components.filter.sensor] Outlier nr. 3 in sensor.123_test_sensor: 5.0
2025-03-31 14:57:57.116 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=5) -> 1.6
Then updated from 5.0 to 1.6
2025-03-31 14:58:01.701 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=5; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:57:57.112598-04:00>, new_state=<state sensor.123_test_sensor=1.6; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:58:01.698912-04:00>>
2025-03-31 14:58:01.703 DEBUG (MainThread) [homeassistant.components.filter.sensor] Outlier nr. 4 in sensor.123_test_sensor: 1.6
2025-03-31 14:58:01.703 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=1.6) -> 5.0
Then updated from 1.6 to 2.0 by 0.1 increments
2025-03-31 14:58:04.161 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=1.6; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:58:01.698912-04:00>, new_state=<state sensor.123_test_sensor=1.7; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:58:04.158100-04:00>>
2025-03-31 14:58:04.162 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=1.7) -> 1.7
2025-03-31 14:58:06.874 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=1.7; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:58:04.158100-04:00>, new_state=<state sensor.123_test_sensor=1.8; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:58:06.871061-04:00>>
2025-03-31 14:58:06.874 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=1.8) -> 1.8
2025-03-31 14:58:09.425 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=1.8; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:58:06.871061-04:00>, new_state=<state sensor.123_test_sensor=1.9; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:58:09.423232-04:00>>
2025-03-31 14:58:09.426 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=1.9) -> 1.9
2025-03-31 14:58:13.895 DEBUG (MainThread) [homeassistant.components.filter.sensor] Update filter on event: <Event state_changed[L]: entity_id=sensor.123_test_sensor, old_state=<state sensor.123_test_sensor=1.9; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:58:09.423232-04:00>, new_state=<state sensor.123_test_sensor=2.0; state_class=total, unit_of_measurement=kWh, friendly_name=123 Test Sensor @ 2025-03-31T14:58:13.892191-04:00>>
2025-03-31 14:58:13.896 DEBUG (MainThread) [homeassistant.components.filter.sensor] outlier(sensor.123_test_sensor=2.0) -> 2.0
So if you can see the 5 values are still showing up
Why does it not filter out these results?
