I have defined a filter sensor to filter outliers from a sensor (a REST sensor retrieving air quality data):
- platform: filter
entity_id: sensor.pm_raw
filters:
- filter: outlier
window_size: 4
radius: 5
According to the documentation (https://www.home-assistant.io/components/sensor.filter/) this should replace any value which is higher or lower than the median of the four previous measurements ± 5 with the median of the four previous measurements.
Actual results are, however, quite different:
In this example, it correctly identifies the outlier, but seems to replace it with the previous value (not the median of the previous values). It goes back to normal after the next, non-outlier, measurement:
2019-02-18 15:48:10 DEBUG (MainThread) [homeassistant.components.sensor.filter] outlier(sensor.pm_raw=39.4) -> 39.4
2019-02-18 15:53:10 DEBUG (MainThread) [homeassistant.components.sensor.filter] outlier(sensor.pm_raw=38.0) -> 38.0
2019-02-18 15:56:10 DEBUG (MainThread) [homeassistant.components.sensor.filter] outlier(sensor.pm_raw=39.0) -> 39.0
2019-02-18 15:58:10 DEBUG (MainThread) [homeassistant.components.sensor.filter] outlier(sensor.pm_raw=38.5) -> 38.5
2019-02-18 16:03:16 DEBUG (MainThread) [homeassistant.components.sensor.filter] Outlier nr. 1 in sensor.pm_raw: 59.2
2019-02-18 16:03:16 DEBUG (MainThread) [homeassistant.components.sensor.filter] outlier(sensor.pm_raw=59.2) -> 38.5
2019-02-18 16:05:30 DEBUG (MainThread) [homeassistant.components.sensor.filter] outlier(sensor.pm_raw=38.8) -> 38.8
In the following situation, however, the sensor gets completely stuck and continues to replace any following measurement with the same value
2019-02-18 19:23:20 DEBUG (MainThread) [homeassistant.components.sensor.filter] outlier(sensor.pm_raw=36.1) -> 36.1
2019-02-18 19:26:11 DEBUG (MainThread) [homeassistant.components.sensor.filter] Outlier nr. 4 in sensor.pm_raw: 44.0
2019-02-18 19:26:11 DEBUG (MainThread) [homeassistant.components.sensor.filter] outlier(sensor.pm_raw=44.0) -> 36.1
2019-02-18 19:28:10 DEBUG (MainThread) [homeassistant.components.sensor.filter] Outlier nr. 5 in sensor.pm_raw: 45.0
2019-02-18 19:28:10 DEBUG (MainThread) [homeassistant.components.sensor.filter] outlier(sensor.pm_raw=45.0) -> 36.1
2019-02-18 19:31:10 DEBUG (MainThread) [homeassistant.components.sensor.filter] Outlier nr. 6 in sensor.pm_raw: 44.1
2019-02-18 19:31:10 DEBUG (MainThread) [homeassistant.components.sensor.filter] outlier(sensor.pm_raw=44.1) -> 36.1
2019-02-18 19:33:20 DEBUG (MainThread) [homeassistant.components.sensor.filter] outlier(sensor.pm_raw=38.7) -> 38.7
2019-02-18 19:36:10 DEBUG (MainThread) [homeassistant.components.sensor.filter] Outlier nr. 7 in sensor.pm_raw: 89.0
2019-02-18 19:36:10 DEBUG (MainThread) [homeassistant.components.sensor.filter] outlier(sensor.pm_raw=89.0) -> 38.7
2019-02-18 19:38:20 DEBUG (MainThread) [homeassistant.components.sensor.filter] Outlier nr. 8 in sensor.pm_raw: 84.9
2019-02-18 19:38:20 DEBUG (MainThread) [homeassistant.components.sensor.filter] outlier(sensor.pm_raw=84.9) -> 38.7
2019-02-18 19:41:10 DEBUG (MainThread) [homeassistant.components.sensor.filter] outlier(sensor.pm_raw=37.6) -> 37.6
2019-02-18 19:43:21 DEBUG (MainThread) [homeassistant.components.sensor.filter] Outlier nr. 9 in sensor.pm_raw: 31.6
2019-02-18 19:43:21 DEBUG (MainThread) [homeassistant.components.sensor.filter] outlier(sensor.pm_raw=31.6) -> 37.6
2019-02-18 19:46:10 DEBUG (MainThread) [homeassistant.components.sensor.filter] Outlier nr. 10 in sensor.pm_raw: 30.6
2019-02-18 19:46:10 DEBUG (MainThread) [homeassistant.components.sensor.filter] outlier(sensor.pm_raw=30.6) -> 37.6
2019-02-18 19:48:10 DEBUG (MainThread) [homeassistant.components.sensor.filter] Outlier nr. 11 in sensor.pm_raw: 29.5
2019-02-18 19:48:10 DEBUG (MainThread) [homeassistant.components.sensor.filter] outlier(sensor.pm_raw=29.5) -> 37.6
Starting with outlier nr. 9, every following measurement is identified as an outlier and is being replaced with ‘37.6’.
The same thing happens with 6 different sensors and it goes on forever. Only restarting homeassistant resolves the issue temporarily. I am on version 0.87.1 (but it happened with previous versions as well).
So, my question is if I did anything wrong or have misunderstood the concept, or if this is a bug in the filter sensor?
