Output to speaker attached to host
I am planning to build an alarm system based on HA installed in Raspberry Pi and I am wondering is it possible to output the alarm sound via a speaker/audio system attached to the Raspberry Pi?
Shouldn’t be a problem using https://home-assistant.io/components/switch.command_line/
https://github.com/balloob/home-assistant/pull/1641
