I’d like to be able to adjust a value from a sensor so the adjusted value or something else like a message is displayed.
I use PVOutput to upload lots of energy data too then I link it into HA. I know how to implement rules in PVOutput but not in HA.
My 1st example
PVOuput does not plot data when the figure is 0, so I get a rule to change any 0’s to 1’s. I monitor the energy usage of a fan which displays 1 when not running in HA, I would like to be about to tell HA to change a 1 to a 0 (a reverse of what PVO does) or possibly even better would be to say “FAN OFF” when HA sees 1.
Below is one of my sensors where I’m guessing I can add some configuration data
- platform: pvoutput
system_id: xxxxx
api_key: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
scan_interval: 150
sensors:
power_consumption5:
value_template: '{% if is_state_attr("sensor.wood_burner_fan", "power_consumption", "NaN") %}0{% else %}{{ state_attr(''sensor.wood_burner_fan'', ''power_consumption'') }}{% endif %}'
friendly_name: 'Wood Burner Fan Electricity Using'
unit_of_measurement: 'Watt'```
Wood Burner Fan Electricity "Using". I would like to add some code that if the output is 1 then make it 0 or say OFF.
You were right it was close, it did only need a very slight adjustment, thankyou!
value_template: ' {% if is_state_attr("sensor.wood_burner_fan", "power_consumption", "NaN") or is_state_attr("sensor.wood_burner_fan", "power_consumption", "1") %} OFF {% else %} {{ state_attr(''sensor.wood_burner_fan'', ''power_consumption'') }} {% endif %}'
Not quite perfect though as when message shows "OFF" it actually shows "OFF watt", would there be any way of removing the word watt but only when OFF
