My current 5-in-1 weather station broke down and I’d like to replace it with something cheap as I only want to have outside temperature. What could you recommend? Of course it needs to integrate well into HA.
I have rtl433 running so can be any RF (433 or 866 MHz for example), zigbee or potentially WiFi.
I use https://www.amazon.com/dp/B00IXOM7QK (no longer available at Amazon, but many others from Acurite use the same outdoor sensor cheaply) - works fine with the rtl433.
