Hi there!
I was fighting with the device in subject and finally found the way how to work with it in HA.
Probably this article require Russian translation as far as this device is well known withing CIS region.
So… to read registers of OVEN MK110 or any similar OVEN device you need a RS485 USB converter. Previously I spent a lot of time figuring out why system did not work. The reason was incorrect driver support in Hassio for russian converter. I got other from AliExpress for $2.Once I got Chinese dongle everything went fine.
My device setup in configuration.yaml:
modbus:
type: serial
method: rtu
port: /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
baudrate: 9600
stopbits: 1
bytesize: 8
parity: N
port: value may be found in Hass.io/System/Hardware menu page.
Then you may set up a sensor to read Inputs of the device. Values are stored in 51 register:
- platform: modbus
registers:
- name: InputsState
hub: oven110
slave: 16
register: 51
count: 1
The value received should be parsed by bits, so I set up binary sensors for that and parsed InputsState value:
binary_sensor:
sensors:
power_failure:
friendly_name: "Сетевое питание"
value_template: "{{ states('sensor.InputsState')|int|bitwise_and(1) > 0 }}"
accum_failure:
friendly_name: "Аккумулятор"
value_template: "{{ states('sensor.InputsState')|int|bitwise_and(2) > 0 }}"
switch1:
friendly_name: "Cигнализация"
value_template: "{{ states('sensor.InputsState')|int|bitwise_and(4) > 0 }}"
switch2:
friendly_name: "Вода"
value_template: "{{ states('sensor.InputsState')|int|bitwise_and(8) > 0 }}"
smoke_detector:
friendly_name: "Задымление!"
value_template: "{{ states('sensor.InputsState')|int|bitwise_and(16) > 0 }}"
motion_sensor:
friendly_name: "Движение"
value_template: "{{ states('sensor.InputsState')|int|bitwise_and(32) > 0 }}"
hydro_lock:
friendly_name: "Датчик протечки"
value_template: "{{ states('sensor.InputsState')|int|bitwise_and(64) > 0 }}"
To change outputs state you need to write registers using modbus function 16. And this took time to figure out how it can be done in HA. Finally I found that HA uses this function if value provided for writing is an array.
For writing registers I use automation where first value in the array is what I want to write, the second is dummy just to call function 16:
- alias: Water ON
- platform: state
entity_id: binary_sensor.switch2
to: 'off'
- service: modbus.write_register
hub: oven110
unit: 16
address: 0000
value: [0,0]
- service: notify.telegram_id1
message: "*Water should be ON.*"
Register 0000 is linked to Digital Output #1. Maximum value in output registers: 1000
Full set of registers and its functions are described in the documentation.
