I have a TaHoma account which I use to connect my blinds via a Somfy Connectivity kit. I use OverKiz in HA to run scenes automatically and that all works fine.
I bought a second Somfy Connectivity kit to control a set of blinds which I have under the same TaHoma account.
Somehow it doesn’t appear in my HA integration. I expected that the kit plus entities would appear in the OverKiz integration but it doesn’t. I seem to make a thinking mistake but I can’t figure out what.
I’m facing a similar issue on my setup.
I currently use both a TaHoma box and a Connectivity Kit, both linked to the same account (glad to see Somfy finally enabled multi-site management).
I need two gateways because my TaHoma is too far from the back of the garden to reach the equipment in my veranda.
Here is the problem: whether I use the "cloud" or "local" mode via the Overkiz integration in Home Assistant, the TaHoma devices show up perfectly, but I cannot get the Connectivity Kit to appear. I also tried using the HomeKit Controller integration, but it doesn't detect any devices from the kit either.
The diagnostics are done with the multiple connection kits in a single account. In the TaHoma app it functions well. As discussed if you ad the account to HA only one kit plus devices shows. The other is not to be found n
I meant, you will need to add the gateway to multiple accounts (so multiple email addresses). You can follow the progress in the issue, but we don't support Somfy multiple connections today.
