OVERKIZ and somfy problem
Hello, I set up my tahoma somfy blind by overkiz integrationScreenshot 2022-11-09 072054
but I get an error in the movement.
I have recently installed two blinds in my living room with a Somfy motor.
The problem is that inside HA, it doesn’t work ok.
Pushing the “down” button goes up and vice versa.
Inside somfy app works ok
Any idea?
You can add your diagnostics file here and add more information: [Overkiz, Somfy] Inverted screens · Issue #75301 · home-assistant/core (github.com).
