Hi
Was this commit merged into 0.103.0? If so i wonder why re-enabling the tahoma section in configuration.yaml and deleting the somfy integration led to the same errors as appeared after the 3. December. (which were the reason for me to change to the somfy integration)
Thank you very much! Perfect
Thanks, working.
How to make it work? I have only Somfy integration and no custom components etc.
Can someone give a directions or manual?
You will have to enable the Tahoma component then cretate a custom component like explains here: https://developers.home-assistant.io/docs/en/creating_component_loading.html
In this custom component just update the manifest.json: https://github.com/home-assistant/home-assistant/pull/29918/files#diff-f364ab0278ee3ff73b2c274a5e024904
Ah ok, will try. I made a custom component of tahoma before, but never the API.
To be sure, tahoma as custom component or the API as well?
Just modify the api version in the custom componentâs manifest, you donât have to install the api anywhere, HA will take care of it.
Iâve an error today since the update to Hassio 3.7. Am I alone ?
Error setting up entry Home Assistant Cloud for somfy
File "/usr/local/lib/python3.7/site-packages/pymfy/api/somfy_api.py", line 123, in _request
return getattr(self._oauth, method)(url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 546, in get
return self.request('GET', url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests_oauthlib/oauth2_session.py", line 478, in request
url, http_method=method, body=data, headers=headers
File "/usr/local/lib/python3.7/site-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 198, in add_token
raise TokenExpiredError()
oauthlib.oauth2.rfc6749.errors.TokenExpiredError: (token_expired)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 192, in async_setup
hass, self
File "/usr/src/homeassistant/homeassistant/components/somfy/__init__.py", line 90, in async_setup_entry
await update_all_devices(hass)
File "/usr/src/homeassistant/homeassistant/components/somfy/__init__.py", line 162, in update_all_devices
data[DEVICES] = await hass.async_add_executor_job(data[API].get_devices)
File "/usr/local/lib/python3.7/site-packages/pymfy/api/somfy_api.py", line 61, in get_devices
site_ids = [s.id for s in self.get_sites()] if site_id is None else [site_id]
File "/usr/local/lib/python3.7/site-packages/pymfy/api/somfy_api.py", line 42, in get_sites
r = self.get("/site")
File "/usr/local/lib/python3.7/site-packages/pymfy/api/somfy_api.py", line 80, in get
return self._request("get", path)
File "/usr/local/lib/python3.7/site-packages/pymfy/api/somfy_api.py", line 125, in _request
self._oauth.token = self.refresh_tokens()
File "/usr/src/homeassistant/homeassistant/components/somfy/api.py", line 31, in refresh_tokens
self.session.async_ensure_token_valid(), self.hass.loop
File "/usr/local/lib/python3.7/concurrent/futures/_base.py", line 435, in result
return self.__get_result()
File "/usr/local/lib/python3.7/concurrent/futures/_base.py", line 384, in __get_result
raise self._exception
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 403, in async_ensure_token_valid
new_token = await self.implementation.async_refresh_token(self.token)
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 81, in async_refresh_token
new_token["expires_at"] = time.time() + new_token["expires_in"]
KeyError: 'expires_in'
Anyone else getting HTTP 400 errors?
Which version of Home Assistant is installed with Hassio?
The last one : Home Assistant 0.103.0 with Hassio 3.7
I have the same issue, Home asisstant 0.103.0
Wed Dec 18 2019 09:55:12 GMT+0100 (heure normale dâEurope centrale)
File "/home/homeassistant/.homeassistant/deps/lib/python3.7/site-packages/pymfy/api/somfy_api.py", line 123, in _request
File "/home/homeassistant/.homeassistant/deps/lib/python3.7/site-packages/requests_oauthlib/oauth2_session.py", line 478, in request
File "/home/homeassistant/.homeassistant/deps/lib/python3.7/site-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 198, in add_token
File "/usr/local/lib/python3.7/site-packages/homeassistant/config_entries.py", line 192, in async_setup
hass, self
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/somfy/__init__.py", line 90, in async_setup_entry
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/somfy/__init__.py", line 162, in update_all_devices
File "/home/homeassistant/.homeassistant/deps/lib/python3.7/site-packages/pymfy/api/somfy_api.py", line 61, in get_devices
File "/home/homeassistant/.homeassistant/deps/lib/python3.7/site-packages/pymfy/api/somfy_api.py", line 42, in get_sites
File "/home/homeassistant/.homeassistant/deps/lib/python3.7/site-packages/pymfy/api/somfy_api.py", line 80, in get
File "/home/homeassistant/.homeassistant/deps/lib/python3.7/site-packages/pymfy/api/somfy_api.py", line 125, in _request
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/somfy/api.py", line 31, in refresh_tokens
File "/usr/local/lib/python3.7/concurrent/futures/_base.py", line 432, in result
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/config_entry_oauth2_flow.py", line 403, in async_ensure_token_valid
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/config_entry_oauth2_flow.py", line 81, in async_refresh_token
same here.
just a guess, but could it be that somfy changed something on their side? i deleted the integration and if i want to set it up i get an error on their website.
Just upgraded and getting the same error.
Same here. Token expired error.
@Rhadamantys @TheNr1Guest @mase @medaemon Are you all under Hass.io or HA? Which kind of integration are you using the cloud one or the custom one (using your own app created on the Somfy website)?
Hello, HA for me and I have tried both cloud integration and then created my App on Somfy dev site. In both cases I have the same error.
I hade the TaHoma integration but it have stoped working so i tryed this component and i dont find any of my blinds. I have tryed what was written in the first post and have send a mail to Somfy but no answers.
So my quiestion how the hell do i get my blinds in my Home Assistant?
TaHoma doesn´t work and Somfy official api doesn´t work.
Can someone please expelain to me like i´m a three year old
