? Besides interrupting a current motion, the My button acts as a command for a pre programmed position. Which is necessary for these RTS motors since they donāt provide feedback for their current position.
I havenāt seen this error yet, maybe there has been an update to the Somfy TaHoma servers. This feature still works for me. Feel free to create a bug report on GitHub.
o really? is that intentional, seems a bit surprising to me, maybe the devs want to mimic the My buttons stop function the other way around.
I can understand a My button to have 2 functions, depending on the current state (moving or not) but dont think it is god practice to have a single service have 2 effects.
I suspect working within the confines of a āstandard coverā in HA, which doesnt have the My function, it was probably the most straight forward way of doing it.
This is not always the case, you are currently using an āundocumented featureā. We first try to cancel the current execution, however as a fallback, we call the stop buttons. The last resort is the My button, which cancels a running execution as well.
If you have RTS covers, it could be that this is the behavior you see, but normally the stop button should not be used for my position.
Iāve been playing around a bit with what I think is the same issue. I also run a Connexoon RTS hub in Australia.
I find that after successfully having the integration working, that the authentication will stop working after a few days (Iām taking notes now to try to figure out exactly how long).
Today i deleted and readded the custom integration but was met with the same invalid_auth error at the setup up screen. What I found worked was visiting https://www.somfy-connect.com/en/ and logging in (which then takes me to the tahomalink log on screen, which I canāt log in to). After taking this step, the same credentials worked seamlessly in the HA interface to add the custom tahoma component.
If I can reproduce these steps in a few days time when I expect it to fail again, Iāll log an issue on github.
Donāt really remember what I did but soon after my post it started working. I remember I upgraded the custom integration and the I think it just started working. It stopped working once but the there was a new version again of the integration in HACS and after upgrade everything was fine again. Havenāt had to re auth or anything.
And yeah, logging in on the Tahoma site doesnāt work for me either. Only on somfy site.
Hi folks, do you also have such problems with updating the position of your shutters? When I raise/ lower my shutters manually, I get the status in Home assistant only after about 1h.
Could you create an issue on GitHub? Have a look at your update interval as well, this controls this feature. (if you donāt have specific covers that only update after a hard refreshā¦)
Hi guys,
today after a Tahoma official upgrade the integration with HomeAssistant stopped working.
I tried to reload and to restart multiple times HomeAssistant without success.
I had to remove the itnegration at all and then reconfigure from the beginning, but unfortunately the Solar sensor, previously wroking fine, is not anymore present in HomeAssistant.
I tried with the official integration and with the custom component in HACS.
installed, reinstalled, removed, reinstalledā¦rebootedā¦bla bla bla.
Solar sensor is not anymore imported in HomeAssistant.
