Okay it is strange that there is no stop functionallity.
What about discrete mode?
Is that possible? (So the slow speed)
I havenāt such covers. I donāt know. But I think itās not supported.
I would say this is not supported, since this is not supported in HomeKit. In my case, unfortunately they donāt support my light and pergola cover, thus HomeKit is rather useless for me.
However, for some users this could be great solution!
Hello. My first post and a complete HA beginner but I was able to set-up within 5 minutes my RTS covers (connected to Tahoma Switch) with your Overkiz API. Many thanks! My question: the āMy positionā on the RTS covers is also working through your integration (triggered through scenes performed in the Tahoma App) but Iāve also some old RTS receivers (PF versions, approx. 20 years old) that does no offer the My Position function at all. Is it possible to perform a time-based script (e.g. close for 30 seconds and than open for 1 second) and if so, can you share a code-template? Or do i need to buy newer RTS (or IO) receivers to perform a My position?
Okay that is bad news for meā¦.
HA component must only expose features implemented by a device.
In your case, you can create a script to open or close your cover, wait and then stop.
Many thanks Tetienne! Iām almost there. The following script works - but I realized that the actions are performed in parallel and not consequently. I therefore included a trigger of ā58ā to allow enough time from fully open to close with the disadvantage that it takes 58s for the upward command when the cover is nearly closedā¦do you see a more elegant way than the following
storen_wohnzimmer_angewinkelt:
alias: Storen Links Wohnzimmer angewinkelt
sequence:
- device_id: 47a065a2bb4bf8b1c95638b96ea64622
domain: cover
entity_id: cover.storen_links_wohnzimmer
type: close
- wait_for_trigger:
- platform: device
domain: cover
type: closed
timeout: '58'
domain: cover
type: open
- wait_template: ''
continue_on_timeout: true
timeout: '1'
domain: cover
type: stop
mode: single
I donāt like the automation using device.
I would image more something like:
alias: Close and Stop
sequence:
- service: cover.open_cover
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
- service: cover.stop_cover
mode: single
Are there no possibilities to change this behaviour?
You could not reconnect automatically? The problems of banned i have never had before.
Today it occurred another time, while i get push notifications that some automations are running while the covers could not controlled.
Your suggestion about the check if reauthenticate is necessary i still not have found
Many thanks! Simple and works.
With various tests I have found that automations with RTS blinds does not turn out to be reliable. If I send the close command ahead of your script including a wait of 58 seconds to allow full closure, then the whole sequence (close/wait/open/wait/stop) works in 6 out of 10 cases. In the other cases the blinds usually remain closed. Must be related to the RTS technology. RTS really only seems to be suitable for simple commands like close, open and my position(if available).
If have also some Shellyās 2.5 with other covers. Extended script with closing/wait ahead of your script works reliable. No errors so far.
Hi!
I have a Somfy box Tahoma V1.
The status of my various devices are really slow to be updated into HA, sometimes up to 1h.
Is it due to the cloud API, or it is a limitation of this hardware?
NicoLeOca
It should be 30 seconds maximum, or when you hard refresh all states by opening tahomalink.com (in case of devices like the Pedestrian Gate).
Could you open an issue on GitHub with your debug log, so we can investigate?
Hi @imick
For instance, when I open (or close) my garage door, the state is long to be updated automatically. But it is updated, as soon as I opened the Somfy app.
My understanding of this phenomenum is that the state of the garage door is not updated back into the Somfy box very often; but when I open the Somfy app, the somfy box asks the garage door for its state.
Would that make sense?
I am using the Overkiz (by Somfy) - Home Assistant integration to link my Tahoma Switch. This works great, except every week I am logged out of the integration.
My covers (both RTS and IO) arenāt available anymore in HA and I get a warning that one of my integrations needs reconfiguration. In the integrations UI I see Overkiz (by Somfy) needs attention. In the HA log is read āAuthentication failed while fetching device events data: Bad credentialsā.
As soon as I re-enter my credentials I first get a message āabortedā but then all is working again, at least for a while until I am logged out again.
Anyone else bumped into this issue? And any ideas on how to fix this? Itās becoming quite annoying
Also a known issue, have a look at At least one of your integrations requires reconfiguration to continue functioning. Ā· Issue #599 Ā· iMicknl/ha-tahoma (github.com).
We are looking into this, however the main issue is that Somfy is throwing these BadCredentials
errors when your credentials have changed, but also randomly when they encounter issues apparently.
The last days we have seen quite some reports from users, which is not related to an integration update, but related to the Somfy behaviorā¦
I managed to control my SOMFY IO shutters connected to a TAHOMA SWITCH 2 days ago using Overkiz integration. (I did not manage to use the integrated somfy integration as either a quota error - when using cloud access - or an oauth2 error when using private developer api codes occured).
Today the integration was offline because of issue #599:
After reconfiguration the shutters work again BUT *.rssi_level entities and sensor.homekit_setup_code are offline.
Any idea how to reenable the homekit_setup_code sensor? (Iāve noted the code issued - but I do not know when it will probabl change so I would feel better if it can be read)
McM
This will work after a reboot, we will fix this issue soon.
Tracking issue: Config entry has already been setup Ā· Issue #560 Ā· iMicknl/ha-tahoma (github.com)
Thanks for the fast reply
thank you @tetienne
I hope it gets fixed soon as I see it important to have reliable info in home automation
