I have a Tahoma Box V2 - I was very happy that Overkiz was made available and supported as core but had to install a specific PR to get this working for my current setup as SOMFY would ban me for many API calls and delete my account.
Cutting the story short, I installed it via the PR Custom Component, a component installed via HACS.
My other question : iām not sure itās really uses the local API : when my HA server doesnāt have access to the internet, all my device becomes unavaible
Iām with team Jooxā¦ any info? Tonight I set up my Tahoma Switch for the first time. The cloud integration worked solid with HA, but after 1 hour Somfyās API went down for a longer periodā¦
The unavailable issue is a known issue, but I havenāt had time to really look into this. It seems something is not working with our event listener, because we donāt receive all events.
Hey guyz!
Overkiz with cloud stopped working for me with TAHOMA SWITCH.
Can you please tell me if its possible to use the LOCALAPI and if itās working okay?
I will go through this thread when i will be home and will try to figure it out.
Much <3
I am having the same issue since 2 or 3 days ago. It worked fine for a year and suddenly stopped. The reason it unclear to me as I did not trigger any update or similar event. The log is not helpful as it is saying that the devices are unavailable. The devices can however be operated by remote control or the tahoma app.
Iām considering buying a Tahoma hub. The solution Local API via HomeKit Controller , is this working stable? Or is this the solution you are talking about here?
Iām using the controller homekit integration since few years to controller my Somfy covers and my awning. No issue, stable and instant update. The only downside is that the Stop button is not available. So I created a Cover template to mix the Overkiz integration and the Homekit controller.
Thanks Etienne, I just want to open and close my awning in function of the weather I read on Openweather map. Stop is not necessary. In that case do I just need HomeKit controller and no need for Overkiz?
