Overkiz + TaHoma Switch: Devices detected but no commands work
Hi everyone,
I’m having an issue with the Overkiz integration and my Somfy TaHoma Switch.
Environment:
  • Home Assistant Core 2026.7.4
  • Home Assistant OS 18.2
  • Running as a VM on Proxmox
  • Somfy TaHoma Switch
  • io-homecontrol raffstores
  • Somfy garage doors
  • Overkiz integration
Problem:
All devices are discovered correctly.
Device states are sometimes correct and sometimes incorrect.
Status updates appear sporadically.
No commands from Home Assistant have ever worked.
open_cover, close_cover and set_cover_position do nothing.
The same issue affects garage doors.
Everything works perfectly from the TaHoma mobile app.
What I already tried:
  • Removed and re-added the Overkiz integration
  • Updated Home Assistant to the latest version
  • Reloaded the integration
  • Restarted Home Assistant
Diagnostics:
The downloaded Overkiz diagnostics show:
alive: false
connectivity.status: DISCONNECTED
Additional observations:
  • Home Assistant sometimes receives position values (e.g. 99%).
  • Commands appear in the activity log, but the devices never react.
  • Some entities occasionally show as unavailable.
Question:
Has anyone seen this behavior with a TaHoma Switch and io-homecontrol devices? Is this a known issue with the current Overkiz integration?
Thanks in advance.
No, this is not a known issue. Feel free to create an issue on GitHub, where you include your diagnostics and log files (with debug mode on). If your gateway shows ‘alive: false’ and DISCONNECTED, this is most likely an issue with your gateway / configuration.
