after following the instructions in the overkiz integration, everything seems to work until I hit submit, then I get the error:
Invalid flow specified
the host name is correct, and I tried to use the IP address directly, but it doesn’t make a difference. I tried to generate a new token, but again, no change.
any suggestions? is there a place where I can get more details on the failure?
version of the tahoma: 2025.2.5-6
developer mode enabled.
