so for domains such as lights and fans where there are levels when setting devices to on - eg. 50% brightness or low/med/high, does anyone know if there is a way to override the default on level of a device when it is controlled through HASS? So for example, when my fan is turned on through frontend or alexa, it goes to high - which I personally find to be annoying.
You sure thatās not your device? My devices remember previous brightness states. When I call turn on from alexa, she just turns them on at whatever brightness they were at when turned off unless i specify āto 100%ā.
EDIT:
to clarify, Iām using alexa -> emulated hue -> hass
I donāt have any fans, but certainly for lights and volumes I get the same behaviour as @petro where if I switch something off, when I switch it back on it will be the same level unless specified otherwise.
What component are you using? Iām wondering if perhaps this is related to that as mine always revert to 100% either way, I donāt want ālast usedā - I want to set the default behavior
