Overview panel disappeared
After updating Home Assistant Core
2026.1.3 to 2026.2.3, the overview panel I created disappeared.
I don’t need such updates.
Only restoring from a backup helps.
HA is installed on a Raspberry Pi 3.
With it’s 1 gb of memory, that pi is probably struggling to keep up.
Every update is bigger and your problems will just continue to get worse. Consider a better server or not updating to solve that.
I don’t think it’s about memory, because the system displays the regular overview panel, it looks like this is a bug
Is it possible to save my own panel in a separate file?
so far, I have to restore the old version from the backup
Go to /Setting/Dashboards, there you should find your “old” Overview, moved from built-in To the the User-created Dashboards, Below
Then click to the right 3 Dots, Set As Default !
I saw the panel and it can be set to use by default, but after the update the user panel is empty, that’s the problem
ohh, sorry to hear :frowning:
Replacing pi3 with pi4 didn’t work.
After updating, the user-created overview panel is empty.
How do I save the panel? Help!
Why such wonderful updates?
how can I save my panel after update?
Version 26.3.2 also removed my panel, or rather replaced it with an empty one
another update and another replacement of my panel with an empty default. I have to restore the backup and not update.
How do I save my dashboard so that these wonderful updates don't break everything?
also, restoring from a backup does not restore the normal version of the system, and I will have to start with a clean memory card.
Starting all over again. This cr@p can't be restored from a backup.
So much work wasted.
